1800 ZVH Questions
24 posts • Page 1 of 1
1800 ZVH Questions
Was thinking about this the other night but couldnt find any examples when searching.
Has anyone swapped to an 1800 zetec bottom end and decomp plate set up as a budget replacement for a knackered 1600 CVH bottom end.
Was just wondering if it is possible to run an 1800 ZVH (standard pistons and decomp plate) using a 195 chip and beige injectors?
I know the usual ZT over ZVH argument but im thinking from a cheap alternative and not looking at massive power gains, just a decent increase in bhp and lower down torque.
So has anyone got this sort of setup and how does it run?
Chris.
Chris.
- CRF
not too sure bout that. Too be honest m8 u'd b best of ringing an engine builder and asking them for some advice about it and they will be able to tell you everything u need to know bout it.
- niracka
- Your car: E46 M3
You know Ian's the man Chris, holla at him see what the dealio!
You Blackpool people have been keeping yourselves to yourselves haven't you? What's going on with you all? I've got my car with me at uni now, so will bob over if you're all around at some point?
How do mate!
Surprised no one's done it before to be honest.
Long time no see, this weekends probably good mate. Not got anything planned myself, apart from giving the fez a good clean, its filthy at the moment!!!
Sure matt will be happy to take you out in the new evo if you pop down as well.
- CRF
I'm going down to Urban Racing for my new tyres on Saturday afternoon, but if I get back up here at a reasonable hour I may well blast over there, I'll give Matt a bell if I can get there before 5ish or something, which I should be able to!
So he DID get one in the end! I haven't spoken to him for a couple of months, so didn't know he picked one up in the end. Did he get a V in the end? Fill me in! Is Leigh's still going strong?
Sounds good to me mate.
Yeah, it's a V but has been dressed up as a VI while in the land of the rising sun.
Sunglasses recommended......
http://www.lancerregister.com/showpic.php?pic=car_register/images/19521.jpg
- CRF
Re: 1800 ZVH Questions
CRF :Was thinking about this the other night but couldnt find any examples when searching.
Yeh i want to know the same to, esp about the chip and injectors. Can u still use a stage1 (195 superchip) or that wont be anygood and its best to get one mapped?
Chris.
- reisskahn
id be interested to now this as well im suprised no ones really mentioned it before as it seems a simpler option for a quick power gain
what exactly would be required to do it
- fiestamk3.5
Well i spoke to my tuner and he strongly advised me not to go for this kind of a setup. Well the bottom end i seen was a 1.8 zetec all converted for a cvh head etc so its a zvh but the pistons were skimmed to lower the compression.
So my tuner said
1.) Pistons have been skimmed so they would be weaker and not as strong
2.) Ill really be limiting myself on how much boost i can run. He reckons i could only be running 12psi and some other places ive read is maybe 15psi but thats really pushing it. So unless ive got a decent top end and turbo etc 12psi is kinda nothing and am looking for at least 200bhp
Of course if the conversion was done with the proper pistons i.e forged or low-comp ones etc then it would've been another story but that all just adds and prices up if it was like. So you cant really say that was a quick and cheap solution for any of us tbh.
Am in a situation where my standard 1.6 bottom end has gone, well theres a crack in the block to make matters worse so i cant even rebuild it and dont really wanna go and spend mega bucks for another bottom end.
Am already running beige injectors, stage3 big valve head, t3 turbo and dont really know what to do.
There is a 2.0 zvh bottom end but thats well out of my price range so am gonna just try to find another standard bottom end
Oh forgot to ask
Whats worse using a decompression plate or skimming the pistons??
Oh forgot to ask
- reisskahn
Oh forgot to ask
Skimming pistons, it makes a weaker set-up weaker.
Oh forgot to ask
- Brammer
- Your car: Sierra Cosworth
the pistons on the 1800 are thicker than the 2000 pistons you can skim 1800 pistons but not 2000 pistons i have a 1800 zvh running beiges 195 chip hybrid t3 with 22psi high boost and 11psi day to day driving and that engine has been running for the last 9 months without a hitch
- turboben1
Yeh i figured out that skimming the pistons would weaken them so you cant run high boost or drive the car hard!!!!
'Tuboben1' have you skimmed your pistons on your 1.8 zvh??? If so by how much and am very very suprised that your running that kind of high boost on standard skimmed pistons.
Are you using a decompression plate by anychance and how often do you run the high boost???
Everyone that i talk or discuss with regarding this conversion doesn't recommend skimming the pistons regardless what boost you wanna run.
I was told that if i really really wanted to go with this setup and for the engine to be safe and reliable i could only run about 10-12psi for daily driving but for that theres still no guarantee.
They all cant be wrong can they
With your beiges, t3, and 195 chip what kind of power are you running @ 11psi has i have a smiliar spec???
- reisskahn
pistons are skimmed 3mm with a felpro zvh head gasket no de comp plate high boost is only needed when i feel the need which is basically every morning when late for work only really use 11psi when driving around the town the engine also has a front mount intercooler to keep charge air temps as low as poss
hope this helps
hope this helps
- turboben1
