1985 Capri 2.0 Laser
Re: 1986 Capri 2.0 Laser project | Lowered & Running
Postby Gus!! on Wed Jan 02, 2013 1:05 am
:o i love capris!! They are like sex with wheels on!! :lol:
Gus!!
Your car: Mk3 Fiesta ghia 1.1!!
Postby Michael! on Wed Jan 02, 2013 1:32 am
Sack the mk2 off and finish this!
ft-com-members-map-vt190192/
Michael!
Postby jonyb4 on Mon May 20, 2013 11:08 pm
shes baaaaaack!
got her running again today thanks to a mate, a helping hand was needed to reset the ign timing, and to operate the choke, throttle on the Dellortos as well as adjust the dizzy to get it to start!
Video of the Capri running
sorry for the poor quality, i wasnt prepared and its a rubbish sound quality off my phone
the twin 40's sound very nice
needs rejetting now to suit the engine, and a linkage kit! awaiting payday :wink:
Re: 1986 Capri 2.0 | Running twin 40's
Postby jonyb4 on Sun Jun 09, 2013 6:34 pm
the beaut is running and driving once more :D
as the funds for the dellorto jets/linkage etc builds ive fitted the single variable venturi carb and manifold from the 1.6 mk1 capri we have, needs some stobe light adjustment to get it spot on but she drives! only in and out the lane to get it up to temp and turn it around to garage it front in first
now i can finish lowering the car (passengers side),fit the n/s 2.8 brake and bleed the lot in, bit more body work to sort and i also need to fit the auto throttle cable into the carb
and we'll give it a bash at an MOT
my plan to get this to Ford Fair is looking ripe more than ever :D
Postby jonyb4 on Mon Jun 10, 2013 1:52 am
shock off, lowering spring fitted, and painted black, notice the new lower arm to go on
vented disc fitted to the hub
and the final braided hose fitted
the Carburettor & Motorcraft distributor
plenty to crack on with tomorrow while the enthusiasm from it driving is there! :P
clean up the rear arch as there is a bubbling of rust, fit the -2" block to the rear, the exhaust is leaking and hanging, needs attention and a new rubber
also need to plumb in the rest of the coolant hoses, and wire in the adjustable fan control unit
Postby jonyb4 on Tue Jun 11, 2013 12:10 am
shock back on, brakes on, quite happy with how it looks black and gold
refitting the lower arm is a Bic™ on these, hard to use some pretty worring levering but got there :)
Postby ben17southport on Thu Jun 13, 2013 9:01 pm
looks good jony.
how on can you work with all that clutter lol?
fifi
ben17southport
Your car: Ford Fiesta mk3 Si
Postby jonyb4 on Thu Jun 13, 2013 9:08 pm
not so bad when your in there, unless you mean the worktop, trust me i have enough goes at my dad but he keeps undoing my tiding
Postby ben17southport on Thu Jun 13, 2013 9:11 pm
Lol tbh i used to be a terror myself for it. Had to do something about it. It's a lot easier now but yes, it cant be good when you have someone else making it messy for you!
fifi
ben17southport
Postby jonyb4 on Thu Jun 13, 2013 10:34 pm
about it, i have little choice, to much s**t in there and no where for it all to go
Postby jonyb4 on Sat Jun 15, 2013 5:04 pm
all lowered, sitting 2 inches lower all round, and driving
some engine work to do now, eg bleed coolant, fit choke, and gearbox throttle
Postby dontpannic on Sat Jun 15, 2013 5:53 pm
What's it doing on the road?
Postby jonyb4 on Sat Jun 15, 2013 5:57 pm
how much is the tax now?!
ha cheers for that i now know its a 85 not an 86 :P
Re: 1985 Capri 2.0 Laser
Postby jonyb4 on Wed Jun 19, 2013 12:39 am
Getting there
took the dash apart to do a number of things
first off i had another lower panel with a choke cable fitted, i was going to swap them over, but ours has various things fitted to this panel, eg hazards and alarm indicator lamp
but i noticed the fitted panel had a blanking plug for a choke, i popped it out and fitted the choke, used the standard bulkhead slot, and attached the cable to the carb
while the dash was in pieces, i took the dial panel off, and pulled the cluster forward to access the bulbs.. i fitted white LED 501 bulbs to the 4 dial bulb holders (my last four from when i did the same to the mk2 fez)
the result is a much brighter illumination, the capri is has a notoriously dark dash light at night
while the panel over the cluster was removed, i remembered how plenty of people liek to paint the bazels, red comes to memory
i didnt fancy that though, i went for silver, simple spray can into a cap and cotton bud method
bad photo
pic of them in use
(they are more aqua then blue, led bluey/white mixed with green filters) they are far brighter than before :)
getting close to mot time!
Previous
