1991 FORD FIESTA XR2I 8 VALVE CVH WITH ONLY 22,000 MILES
7 posts • Page 1 of 1
Hi I am new to fforums and have been encouraged to share my recent purchase. I did put a post on previously but it wasn’t very well written so I thought I would start again and try to put together a better post.
I recently sold a 98 plate fiesta and my much loved Saab 900 convertible. I did this in a fit of being sensible and wanting to buy a family car. I had thought of doing this when my little girl was born but managed to put it off for three years. So I went and bought a Ford Fusion 1.6 Automatic. My wife was happy however I was a more than a little distraught and took to cycling everywhere. I argued with myself thinking I have done the adult thing and at 35 its time to grow up and be an adult.
I’ve owned all kinds of cars both cooking model cars and performance cars but Fiestas have always held a special place in my greasy heart. I have owned two Mk2’s and an Mk3 and Mk4 Fiesta and of course the Fusion which is a Fiesta on steroids. My first car was a mk2 Fiesta 1.4 Ghia. Everyone thinks I am mad squeezing my 6”3 inch frame into a Fiesta but they just have a certain allure.
After several months of sensible car ownership I decided to start looking for a replacement retro car for myself. I was willing to go for anything but kept gravitating back towards Fiestas particularly Mk2 XR2’s. I had a grand in my pocket but after months of searching I could not find one that was not rotten or generally ragged.
I finally came upon my current car an XR2i in Grey with only 22,000 miles on the clock all genuine. At first I couldn’t believe it 22,000 miles the seller was backing it up with all the old MOT’s. I enquired and the car had changed hands between friends several times as they couldn’t afford to insure the car. The last owner had been given a work van and had had left it standing. The car was doing 100 miles a year by now which was to drive it up and down the road occasionally and an annual pilgrimage to the MOT Centre.
Being a cynical so and so I carried out HPI checks and MOT checks all of which backed up the mileage.
I spoke to the owner who explained all of this and went to Slough to pick it up. When I got there I couldn’t believe it the condition of the car backed up the mileage it even had then new ford car smell which took me back a decade or two. Not a spot of rust so original thoughts were drive it back give it a quick clean and away I go. Whilst driving her back the 80 miles or so home I started making lists of things to do. Anyway here are some photos.
The exhaust has a slight blow and I need to source and replace the boot stickers. I found the ford logo badge in the boot where the car had been debadged. Also needed a replacement rear cluster which had gone crusty this was sourced and posted to me by Hamps another forum member and is spot on.
Again no rust around the petrol cap. Whilst cleaning I got all the mud and gunk out. The reason they rust in this area is that mud literally sits up on top of the petrol filler pipe holding water against the wing and the inner arch causing the horrific rust. This car hasn’t been affected due to the low miles she has covered.
The roof again in immaculate condition apart from the rain covers which have been butchered to fit a roof rack. I simply went down to a scrap yard and replaced them. The only other fault was the sunroof was leaking. I replaced the sunroof and tightened the ariel mount with no success. I traced it to the sunroof hinge where the bolts had rusted through and were letting water in. I drilled these outs and replaced the bolts using mastic to ensure they were properly sealed.
I took the opportunity to clean out all the drain holes and made sure they flowed properly.
Got all of the above from a local scrappy for £20
From the driver side just as clean dent free and scratch free.
The interior was a bit grungy but almost no wear just in need of a clean-up. The revcounter and fuel gauge was also knackered but managed to find some clocks of another Xr2i and replace the relevant dials.
Even the original stereo was in place so I got it recoded and works a dream I did have to turn the bass down as the last owner had it cranked up to the max
From the front it still has the original amber indicators these always seemed to get swapped for clear ones. The bonnet was aligned incorrectly and sitting low on one side so a quick tweak and it was sorted and raised to the correct height. The wiper arms are going to be removed rubbed down and re-sprayed in satin black.
And for me in some ways the money shot all perfectly standard and un molested. Well apart from the suspicious brown wire going to the thermostat. Someone had bodged the wiring. This had to be traced back and un bodged by my local mechanic. She was running a little rough so there was more work than I thought needed but more on that later.
I started by giving her a good wash and polish and turned my attention to the interior.
Lifted the boot carpet and found this.
So gave her a good clean and polished the boot floor resulting in this
Took the boot carpet out and gave it three cycles in the washing machine.
It was the originality of the car that impressed me. Even the under tray was still on the car.
The underside of the car was just as good as the rest with no welding or rust.
I washed all the arches and found pristine factory paint.
On with the cleaning the parcel shelf was filthy along the leading edge so after using different cleaners managed to get it cleaned up. Replaced a broken shelf strap and I was away.
Lifted up the rear seat to just find dirt and the usual filth.
So after a quick clean up and polish I had this
Whilst lifting the bonnet and moving the stay arm managed to snap the catch however found this on e bay.
Back to one of the main faults with the car. It was running rough on idle and was over fuelling massively with the smell of petrol following me everywhere.
Tried all the usual culprits HT leads Spark plugs even put a new air filter in as there wasn’t one to start with. Eventually after much head scratching my local mechanic traced it back to seized lifters of all things. It seems that even though it wasn’t run much the oil had not been changed in years and was thick and gunky which these engines don’t like. Took many phone calls to find them but managed to track the lifters down. Turns out ford don’t stock them and local motor factors have issues getting them. Ebay was no good as I had heard too many horror stories.
I decided to overhaul the cooling system so drained the radiator. Loosened the tap and expected the coolant to come out. No such luck the rad was full of gunk as well as not changing the oil the previous owner had been using plain water or very little coolant so I had to squeeze the pipes to get it started and out came the following gunk.
Whilst the weather was bad I managed to track down some original handbooks for the car. I only have a drive to do the work on so am limited to dry days when working on the car.
Also tracked down some original decals with help from the guys on the forum.
Couldn’t help getting some period music on cassette tape for when the car was built
Also Managed to pick up a panel filter for a £1 !!!
She has also had a oil change and filter with the correct grade of oil. The rocker cover gasket was replaced as they have a habit of weeping oil. At present just waiting for some better weather so I can get the seats out to clean up the interior and clean up the engine bay. They are all pretty minor jobs at present. I am intending to get the car back to standard and then rustproof it and then go from there.
The Ariel was leaking and was a bit rough so replaced it with a new one.
The doner set of clocks all I ended up needing was the fuel gauge as can be seen this one is showing half a tank.
Next on the list was the wipers blade arms. Where the car had been sitting all those years the arms for the wipers had been rusting away. So I thought why not refurbish them. I removed them rubbed them all down and gave them a coat in black spray paint. For a first attempt they have come up quite well.
And after painting.
I was quite pleased with the result as I have never tried spray painting in any form previously before. Following on from this marginal success I decided to tackle the mould that had come about due to the water coming in from the sun roof. Armed with a bottle of vanish stain remover and microfiber cloth I was faced with this.
After very little scrubbing thanks to the vanish cleaner I got it to this state.
Pleased that with the results I thought the next day I would take it for a spin. It had the alternator replaced so I thought I was good to go. However the battery thought differently and decided it couldn’t hold a charge fortunately I already had a trip to Cost Co planned and replaced the old lion battery shown below with a Bosch Silvertop at £50 over £40 cheaper than a Halfrauds one. This pretty much paid for the years membership in itself.
Today I thought I would start sorting the exterior. I aligned the bonnet and the boot as it was out of line. With the help of other forum members it was quite a easy job.
The rear light cluster seals had gone and had started leaking. Resulting in the following.
Hants another forum member sent me a immaculate light cluster which I fitted.
The radiator spoiler had come of and this was reattached with some clips.
Apparently protects the radiator and improves air flow.
Ended up with a leaking set of rad hoses so ended up replacing those today. Ford for some reason don’t keep much in stock. I gave the rad a flush with a top tip from a mechanic friend he suggested two dishwasher tablets in the header tank to flush the radiator out and even though it is the second rad flush in as many months it was still full of sludge.
And after painting.
- willowandmikey
Re: 1991 FORD FIESTA XR2I 8 VALVE CVH WITH ONLY 22,000 MILES
Nice work mate,
Keep it up.
Keep it up.
- jamesosman
- Your car: Ford Fiesta Rs Turbo
looks nice fella and origional!
and if you get stuck on parts ('Ford for some reason don’t keep much in stock.') give me a shout as just dismantled a xr2i (-engine)
- sam-si
- Your car: FORD FIESTA
Welcome to fiestaturbo as I said on other forums, tidy car
Demon Dipping UK
website coming soon.
- hamps
looks good bud keep it up
- stevo™
Great find mate! Love it!
- 285Andy
- Your car: fiesta rs turbo
Excellent find !
I love reading updates showing the small things that all add up to make a much nicer car.
Not many people go through this for a xr2i but i actually think these will become more rare than Rs turbos
- knuckles
- Your car: Fiesta Rs turbo
