2.0 ECU, Which One?
15 posts • Page 1 of 1
2.0 ECU, Which One?
I have a 2.0si still running the 1.6 si ECU.
What models/years can I get a 2.0 ECU from?
Which would be the best?
What codes on them do I look for?
How easy is it to swap them? (I know nothing about them)
- Percy!
- Your car: Citreon
Im running DEEP on mine. To change the ECU on a fiesta you need to look in the bay and remove the metal cover on teh top right of the bay which is held in by rivets. Then you need to take the rubber shielding off held on by two 10mm. Then you need undo the bolt holding the ECU connector in. Then go into the passenger footwell and undo the bracket holding the ECU place and slowly pull it out. Then put your new one in
- Sunil_FiestaRS_16V
Fiestasi-Andy :TELL
DEEP
CULT or (COLT)
Slightly off topic, but do you know what the differences are between each ECU?
I want to look out for one now for in the future
Mike
- mike_wall15
Car: 2002 BMW M3
- lazy_arse_pie
- lazy_arse_pie
ECU's
im also in the same situation as percy have an 1.8 in mine still running 1.6 ECU try reading this topic to getsome pointer but even more confused know than before what dose DEEP etc meen and what is the difference is one better for top speed rather than power would be most grateful if some one could help me. THANKS
- gibbsy
maybe one on here http://www.escortbreakers.co.uk/
a 2.0 zetec one on there somewhere
- escortbreakers.co.uk
