2.0 litre zetec help!!
4 posts • Page 1 of 1
hiya i hav just finished my 2.0 litre zetec conversion in my si, but i need some help. i amcuently using the 1.6 ecu , maf sensor and injectors anfd throttle body, [ERRR] difference would swapping to the 2.0 litre items make? because even tho the car is now quik its jus not quik enuff!
- bigtazzsi
A big difference, atm your car will be underfueling in the higher revs because of the ecu, the maf sensor is definately different so that will be affecting it, the 2.0 throttle body is much bigger, so you wont be getting as much air into the inlet as there should be. Change them. I have a spare 2.0 throttle body, PM me.
- RS_Raz
I had an 1800 105ps lump in my si a little while ago with the 1600 ecu and maf and when the head gasket went and i removed the head i noticed the pistons were being eaten away due to using the 1600 maf and ecu, so not a good idea.
- fiesta_rst2
