2.0 ltr XR2i Trackcar - Jan 12
Re: 2.0 ltr XR2i Trackcar - Jan 12
Postby Project_XR2i_Trackcar on Wed Feb 08, 2012 10:26 pm
The gear shift? If so then yeh, initial thoughts are its certainly much better than before. I've not yet had the opportunity to try it out on track though.
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
Your car: Xr2i
Postby Project_XR2i_Trackcar on Wed Feb 08, 2012 11:03 pm
Bit of an update.
ACF-50 and a new wire brush from eBay arrived so I gave the front coilovers a spruce up....
Before
During
After
One of the multi plugs for the thermostat housing broke during the gearbox removal so I robbed half of a surplus loom from my brother so that got replaced, soldered and heat shrunk.
Drive shafts fitted.
Coilovers back in.
Discs and callipers back on.
Wiring & loom zip tied up again.
Induction back on,
The gearbox oil arrived so.....
Gearbox filled.
Linkage adjusted.
Lower strut brace back on.
Bumper back on and......
Wheels back on and lowered on to garage floor.
Tightened the drive shaft hub nuts.
Tightened the wheel nuts.
Took it for spin up and down road and check all gears engaged ok, which they did.
Reversed it into garage, jacked up, on axle stands and ready to strip the rear coilovers down.......
Pretty rusty, surface rust only thankfully.
Although the adjuster knob is very tight so soaked with WD40 overnight.
I only had a hand held wire brush so I got this far and sacked it until i got a wire brush fitting for my drill.
Wire brush purchased, cleaned, lubed with ACF-50, reassembled and fitted back on the car.
And that's it for now.....
Your car: Xr2i
Postby Turboboy67 on Wed Feb 08, 2012 11:35 pm
Good work mate, what poundage springs are you running on the coilovers ?
Turboboy67
Your car: 911GT3 RS
Postby - Danny Boy - on Thu Feb 09, 2012 12:40 am
Good stuff! I'm always keeping on top of my avo's cleaning them up ect, especially seeing as my car is a daily on the road. Love it when they are all clean and lubed up :aviator:
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Wittmann on Thu Feb 09, 2012 3:10 pm
Do you still have that OMP steering wheel? If you might sell it?
About that plate for the gear linkage can you measure how thick it is. Just guessing something like 20-25mm.
Wittmann
Postby Project_XR2i_Trackcar on Thu Feb 09, 2012 4:07 pm
No. I don't sorry.
Next time I'm under the car I'll measure it.
Your car: Xr2i
Postby jayrs on Thu Feb 09, 2012 8:44 pm
avos have come up well mate.
Postby Dave G fsi on Thu Feb 09, 2012 9:19 pm
Looking really good mate :aviator:
Dave G fsi
Your car: Mk1 FRS and FRST
Postby Project_XR2i_Trackcar on Thu Feb 09, 2012 9:54 pm
Cheers guys :wink:
Your car: Xr2i
Previous
