2.0 Throttle bodies and gearbox!
5 posts • Page 1 of 1
Would I be right to think that my car will still be running 1.6 si throttle bodies and gearbox.
So with the throttle bodies is there any way of checking what I have?
The gearbox is the 1.6 si one as far as I know.
Now heres the problem I am going to be adding a T3 turbo and hopefully be pushing over 200bhp.
The gear box is very short already and I have to change thru the gears quick and I assume I will have problems running the 1.6 throttle bodies with that too.
So what throttle bodies and gearbox should I go for? I want them to be direct swap aswell.
Where can I get them from?
How much should I expect to pay?
Thanks for your help
- Percy!
- Your car: Citreon
Hi,
The 2.0 gearboxes are MTX75...
They are a PITA to fit in a Fiesta! Bigger and different mounts
Save money to buy a Quaife BC kit, then do more mods to get 250bhp may be? (I am not sure if it is okay to push 200bhp using your original gearbox... probably not I believe)
Why do you think you have a 1.6 throttle body though?
- wywywywy
The 2.0 TB has a notch on the top of it that runs at an andle form left to right, also it easy to check by looking inside as the 1.6 has a tiny gateway on it where as the 2.0 is almost same size as the front of the TB.
Jay
Jay
Call 01753 632811 or visit http://www.xfactormotorsport.co.uk
- xfactor
- Authorised Trader
