2.0 throttle body and maf
4 posts • Page 1 of 1
right i have just fitted a ported and polished 2.0 throttle body and a 2.0 maf to my 1800 zetec xr2i and now when i plant my foot flat to the floor there seems to be a flat spot befor it takes off could this be a lack of fuel?would 2liter injectors fix this HELP!
- SHAUNSFIESTA
Re: 2.0 throttle body and maf
No need to run the 2.0 MAF with the throttle body this could be your problem as the MAF's are different and will give your ecu a wrong reading putting in 2.0 injectors without remapping will just make the car run rich.
- allinking
the second you put the 2.0 MAF on you will get crappp low down torque and a massive flat spot at about 2800 IIRC.
put the old one back one.
what MAF is it? AA or AB?
- JoeyZetecT
FITTED THE 1.8 MAF BACK ON TODAY AND ITS PERFECT GOS SO MUCH BETTER CHEERS!
- SHAUNSFIESTA
