2.0L Tuning
14 posts • Page 1 of 1
2.0L Tuning
Hi All,
I have transfed my boarding 1.6 si to a 2.0 now for sometime.
I have changed the gearbox to a short ratio monster LOL
But its time to do a little more what mods do people recommand for there 2.0L
All so is the 1.8 MAF the same size as 2.0 as I am using the 1.6 inlet pipe and causeing resurtion which is a pain.
- Luke_Si
You need a 2.0 MAF + ECU From Same car.
Try a focus inlet?
1.6 Inlet is slightly smaller than RS1800 item etc.
Stainless exhaust? De-cat? Manifold?
Try a focus inlet?
Depends how much you want to spend. You could save up to turbo it? Or instead opt for performance cams, maybe cars or whatever they are, and a decent chip or at least rolling road your motor to get it running right. On ebay there are some chips that offer around 8bhp or sumin for like £100 for the zetec. What gearbox do you have on your car atm? If you stuck with the si one, an xr2i has a shorter second gear and longer 5th for economy.
- lucasdemoley
Guys it seems you have not understood thanks for the help.
I am using the following setup
1800 Inlet Manifold on a 2.0 Engine with a 2.0L TB and 2.0 Injectors with a 2.0 MAF and ECU.
Gearbox I know for a fact is very quick and short in every gear its off a ford car but not a fiesta. Cant say as it took me a while to get the information sorry guys.
But what I want to know is what extra stuff I could do.
I want a 4-2-1 Manifold but its hard to find one that will fit in a fiesta the ashley when needs work to make it fit :(
I have got cat stainless system.
I am going to rolling road it soon which should help a little : )
As well what is a good inlet pipe to use as the 1.6/1.8 is to small for the MAF what have other people done on this problem.
Could you please post a link about the chip and I will look at it but it better not be the MAF one as they dont work LOL
Alll so is there away of making a short shift for these MK3's because the only one I can find is spuid price.
If any one can come up with any thing please post back many thanks.
Also has any one raced on a drag with a VTS Saxo I have and he won only by a ich or so. But I won the first round. Has any else have problems with these bare in mind I had full tank of fuel and he claims he did but I am not sure about that.
- Luke_Si
I have heard that the mk4 fez one fits a mk3 as its the same gearbox, or maybe it was an escort one? One of the traders on ukfn said it would work, but as thats down i cant find the info soz.
As for the chip, im not 100% as its fairly cheap, although apparently it goes into the correct port. When I get my 2.0 in, i'll defo get one if i have the spare cash!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8021647955&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
As for the vts, ive heard that the 2.0 should be on par and maybe abit quicker when running right.
- lucasdemoley
Luke,
I've fitted the Rally Design quickshift kit onto my fezzie! Piecer of piss to do and costs £45 IIRC
Have a look at my thread on Pf.
- BillyCabrio
Give us a link mate
Lower than a snakes bollox
- Big Walker
- Your car: Seat Ibiza
Luke_Si :Guys it seems you have not understood thanks for the help.
I run trust electrical branch. needs a custom de-cat though as it sits on the cross memeber otherwise.
i also run a b&m quick shift with is proper
FOcus inlet will give you a bit more power certaintly made a differnce on mine. but mine aint really std.
Dont have any worries with VTS in mine
- Sunil_FiestaRS_16V
Fitting a focus muti layer head gasket will bring the compression ratio upto 11:1, Cams and head work works well on the Zetec, The best sort of manifold is from a focus again, if you can find one a focussport up and over manifold a bit like the one you see in my sig
- freak power
- BillyCabrio
