2.0L Zetec-E series 2 performance
13 posts • Page 1 of 1
Hi all ,
Having just completed a 2 litre transplant into my adoring si the car seems to be going fine BUT I'm sure there is more power there.
Firstly when I changed the MAF sensor to a mondeo one and plugged it in the car sounded awful, so I refitted my 1.6 version and the car seems to be running fine.
Do I need to change the ECU also? I need more power as the car seems to be running slower than I would have expected?
- Andy - 2.0L Si
yu alright mate where in London you from im just outside north london and have a 2.0 si also.
Youe need a 2.0 ecu either DEEP, TELL or another i cant remember
then you need the 2.0 maff which has a bigger internal diameter and is also the same diameter all the [ERRR] thorough unlike the 1.6 maff, you will find the pipe that usually goes from the 1.6 plenium to the maff will no longer fit. I found a 2.0 mondeo inlet pipe will fit the 1.6 plenium and 2.0 maff or you can use a k&n inlet pipe that goes stright from the butterfly to the maff.
- Sunil_FiestaRS_16V
Re: 2.0L Zetec-E series 2 performance
Andy - 2.0L Si :Hi all ,
i
what kind of power are you running @ the momment ? in bhp terms flywheel or @ wheels
- Xr_Dub
Sunil_FiestaRS_16V :yu alright mate where in London you from im just outside north london and have a 2.0 si also.
Bexleyheath, on the south east side!!
I went to the scrappies and they started telling me that the need specific codes and that it is risky. I guess I need a mondeo 2.0l ecu.
My car had a series 2 1.6 zetec e taken out of it.
Finally I have a K&N pipe but the MAF end doesn't fit over the 2.0l version as it is well bigger? Do I need a mondeo K&N Pipe?
- Andy - 2.0L Si
Andy - 2.0L Si :Sunil_FiestaRS_16V :yu alright mate where in London you from im just outside north london and have a 2.0 si also.
na my k&n pipe was for a fiesta. It was a right baxtered to get over the maff but with a bit of lube and a lot of patience it will go over. And as for a specific code i just took it off a 2.0 mondeo the code doesnt matter aslong as it is a 2.0 one
my pipe fits just inside the MAF sensor and i don't think it will stretch out that far!
did you change the lamda sensor at all?
- Andy - 2.0L Si
are you sure ur trying to fit the right end over. there is small end for the throttlebody and bbigger end for the maff.
no any lambda will do
one big thing i found it the timing mark that is pick up on the inlet cam at the right hand side cause a problem. if you run the 2.0 on 1.6 ecu it well holds back you need to sort the ecu 1.8 youll fine when i tried it just misfired and fires on two spoke to ford technical via a friend at ford ad this is what they told me the problem was
- M K
