2.0L Zetec... fast?
8 posts • Page 1 of 1
2.0L Zetec... fast?
I have been told that when i have the 2L engine is in my fiesta i shouldnt expect it to be super fast... as the engine is mainly torque? i know it will be faster than my 90bhp 1.6 zetec... but what can i expect from this conversion running a 1.6 box? this has worried me a bit ...
Nearly got my car back now!!! it started today just finnishing touches!
- unknown_user
Give up a tech spec, ideally with engineering numbers, of the throttle body, cams (if you know them), MAF, ECU, exhaust, cat, lambda probe, etc; my reason being that you won't normally get the full 130ps until you have everything up to spec.
A true 130ps 2.0L engine should be very capable of keeping up with a reasonably standard ERST/FRST
Al
Al
- Project
- fiftyoneCL
humm in i only know the ecu code which is DESK
i can check the rest when i get me car back hoping 2day!
- unknown_user
i went from a 1.6 16v to 2.0l and the difference in performance is substantaily (spelling) greater. i had a few tweaks, nothing too major and was very pleased with the result.
it is a very fun car to drive, and yes it is very torquey.
- Wude Si 16v
got it back... and it didnt seem faster at all, it wouldnt rev like my old engine... i changed my ecu to the 2L mondey one an it still wernt right.. then i reved it and now it missfires... im a bit upset thinking should i of changed my engine i hope i get it sorted!? before it started missfiring.. it was making a kinda winnning noise like a throaty exhaust or somthing, could of been a slight missfire maybe!? now it sounds like its running on three or well out of time!? but [ERRR] woul cause it to do that!? im worried now!
Any help would b great!
- unknown_user
AFAIK mate the 2.0 mondy ecu doesnt work very well with the engine in a fez, as lou was running this at first and had the same problem. You need an early spec rs1800 ECU, throttle body and possibly inlet manifold tho not sure on the last one as im sure its not 'vital', tho all helps to get you up to the true 130 bhp.
- festajon
yea but would that cause it to missfire? i can understand that causing it to run slow? but now it seems is missfiring... spose that could be the ecu being wrong but id of thought if the ecu was from a mondeo and the engine from my fiesta was from a mondeo then it should at least run ok but not be as fast? the engine sounded sweet before... other option is block compression? spose i better do a compression test!? oh say my cambelt had slipped? [ERRR] would the simptoms be? only that has just been changed ELP plz!
- unknown_user
