2 15"s in the boot?
33 posts • Page 1 of 1
2 15"s in the boot?
if i had a custom box made would i be able to get 2 15" subs in the boot without goin into the back seats or would they have to cum out?
- ChrisD
Re: 2 15"s in the boot?
back seats out mate especially in a fiesta....
what subs are they
bassboy
what subs are they
bassboy
- bassboy
- Authorised Trader
It can be done but the sound would be very poor
- bas saph
15 inch groundzero's 1k wt 600 rms i beleive the 1 is rather loud but i want 2 so it will b even louder =]
- ChrisD
What you could do is have them built facing the back of seat and just hav the seat down then just push it up when have passengers or for obscuring them.
- bas saph
thats what i thought about doing but i thought it would look terrible if i drove around with the back seats down =/
- ChrisD
build a small frame in the boot and make them sit at the top where the parcel shalf would normally be and carpet the top, job done
- dangerousdave
but if i done that where would i put my 6x9s?
- ChrisD
in the bin!!
And you do NOT want to face the subs firing to the back seats!!
Trust me, its not worth the little gain that you will get...and it might not even be a gain...you will lose out on bottom end depth, and it will be punchy as hell...we done it YEARS ago with Sunnys fiesta...would have sounded MILES better with a bigger box! Back then we were nonethe wiser...now we EASILY outperform him 15's with 2 12's in a proper box
its all in the box...thats why ive always been as loud as I am...[ERRR] i know how to design and build a PROPER sub box
bassboy
bassboy
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
so its either have a big box in the boot which takes up all the room and makes the subs come to the edge of the boot or take the back seats out and put them there? hmmm what would you do bassboy?
- ChrisD
if it were me??...I would take the seats out and do what we did to our golf lol
teamspb-new-build-mk2-golf-4-15-s-walled-no-bak-seats-etc-vt179857/
depends how mad u want to go really....
bassboy
bassboy
- bassboy
- Authorised Trader
also depends if you want to draw attention to the fact you have a car full of gear someone will potentionally want to take from you!! i had 2 12" subs in my old 3.5 altho i cracked all the soundproofing on my boot floor there was still a fair bit of space but as bassboy says the box wasnt the best was a small home item with ports but with the right amps sounded good still!
- dangerousdave
Some videos of my 12 in a proper specc'd box can do...(the loudest boot boomer for a single 12 under 1500wrms!!)
This one aint the best but gets moving towards the end
141.9db on the TL - The loudest we have done so far is 142.5@30hz
1 Ascedant Mayhem 12 Flexing a polo's roof
2 Chaos' Flexing the same Polo
2 Chaos' Flexing another Polo
ill get some more up in a minute
bassboy
bassboy
- bassboy
- Authorised Trader
Heres my 12 close up
2 AA havocs flexing a Civic type R
1 12 Mayhem flexing its muscles
And finally, the Golf running half power and no where near finished
bassboy
bassboy
- bassboy
- Authorised Trader
if my sub was all set up proply etc rather than me doin it it should be putting out around the 135db mark but its only doing 127 =[ instead of getting another 15 im thinking of just gettin a custom box for the 1 now but how much would i be looking at payin for a custom box that would pump it out to get the most decibels out of it?
- ChrisD
this might be heartbreaking but you will be struggling for space in a mk3 fiesta to fit a 15 ported...you will need around 4cuft after displacements which is HUGE!
127 is rather poor to be honest if you think its currently loud...my single 12 is 15.5db louder than yours currently
what amp do you have?
Where are you based? You might want to have a listen to some systems varying in degrees of bass so you know what level you want to be at...[ERRR] at the moment, my mids are louder than your sub and I can FULLY understand why you want more...
First start will be to put your sub in a better box...but you will still be fighting for box space...this will DRAMATICALLY increase volume and smooth out the way its currently playing...
Next step will be sort the charging system out so your able to sustain good voltages for a good period of time - you cant make power without power!
Also make sure your midrange and front end are capable of keeping up with the bass...this makes ALOT of difference!! Having a complete system rather than half a system will always sound more pleasing!
I start my boxes from £150...might sound alot but when you consider im over 50% cheaper than most places, its a bargain...and my experience speaks for itself...the box is the KEY point of any install...well...that and a decent power supply! without those, you wont be playing loud for long!
bassboy
bassboy
- bassboy
- Authorised Trader
the loudest system iv heard so far was doing 142db but that was only on quater gain as it was bedding in and only had 1 quater panel done and that was in a puma =P im running my sub off a 1k wt fli amp, im in telford where bouts you from? i might have to come up and have something arranged because my target was to be in the 140 mark but so far im very far away =[
- ChrisD
Im running a L7 12 inch kicker with hyphonics mono amp. That Has enough punch and air displacment to pop the rear window from the tail gate f my mk4 escort when faceing the screen. I had to strap the rear screen down to keep it in. Its now in my mk2 fez boot in the well and Its way to load to have on full, unless the boot is open
- bas saph
wt watt and rms is ur sub and how much was it?
- ChrisD
bas saph...I can safely say, that if your screen was trying to pop out with a SINGLE L7 kicker sub, then your screen werent in right! L7's arent the best speaker to move air...just check the xmax figures...they get loud yes...but their design is flawed in the sense they cant move up and down alot (xmax)
Chris...if you want a 140...ill get you a 140...
bassboy
bassboy
- bassboy
- Authorised Trader
obviouslt wouldnt mind it bein louder than 140 but for now thats what i want unless more can be got out of my sub?
- ChrisD
your a long while away from me as im in west london...
tell me what your will to spend on getting to 140...and ill tell you what you will get for the money...are you willing to change any equipment you have?
bassboy
bassboy
- bassboy
- Authorised Trader
was thinking of spending around the £400 mark but i still want to be able to hear all the music nice and clear, running standard door speakers currently have got 6x9s in the parcel shelf but they are not amped up and 1 of them is blown but i have new ones to go in just dont no how to amp them up, i have all the wiring that i will need i think but im not sure =[ why cant you live closer =P
- ChrisD
wouldnt bother with the 6x9s mate...sell them on or return them and put that money towards components in the front
What amp do you currently have?
bassboy
bassboy
- bassboy
- Authorised Trader
currently using a 1k watt fli amp couldnt i just use the 6x9s as door speakers? XD
- ChrisD
more hassle than its work putting 6x9s in the doors...sell em...make a few bucks, and put them towards a good set of components...
get a nice amp on the components if you havent got one
Try selling the Fli amp and go for something else
Sub wise, like I said its gonna be hard getting that 15 in a proper box in your boot...consider changing down to a decent 12
Invest in sound deadening
Get a bigger battery in the front and possibly one in the boot depending on how much power you are going to run
let me know what your happy with doing from the above
bassboy
bassboy
- bassboy
- Authorised Trader
how much would i be looking at for a new amp and 12" sub that will do what i want it to?
- ChrisD
I reckon your going to need atleast 1k...however, one thing that NEEDS to be taken into consideration, is what sort of frequency do you want it to do 140db??
Balls out SPL cars, tune high...like in the 50-60hz even 70hz regions!! However, it means bass notes around 5-10hz below the box tuning, will suffer and the sub will just bottom out killing itself!
Getting a sub to get the 140's at low frequencies like mine, means power, efficiency and a good box design! My results for my 12 were
20hz - 133.8db
25hz - 138.8db
26hz - 138.9db
27hz - 140.9db
28hz - 141.7db
29hz - 142.0db
30hz - 142.5db
31hz - 141.1db
33hz - 141.0db
40hz - 140.1db
These were dont with an Ascendant Audio Havoc 12"...comes in at £270...there is an Ascendant Chaos which is 800wrms and should just break the 140 figure for £220
Then you have to think about the price of the amp on top...
I really need to measure up your boot to see what will work best
bassboy
20hz - 133.8db
25hz - 138.8db
26hz - 138.9db
27hz - 140.9db
28hz - 141.7db
29hz - 142.0db
30hz - 142.5db
31hz - 141.1db
33hz - 141.0db
40hz - 140.1db
bassboy
- bassboy
- Authorised Trader
my boots the same as any other mk3 fiesta boot apart from its got a big 15" in there at the moment which is in a stupidly big box which is not doin much for it XD
- ChrisD
wouldnt my amp be ok for the 2nd sub?
- ChrisD
The fli amp will only give 500wrms at best! Realistic figure will be around 350-400wrms...you can already start to see why cheap equipment wont work for what you want...
I know your boot is the same as any mk3, but I dont have access to any mk3's for me to look at lol...they are kinda hard to find these days lol
bassboy
bassboy
- bassboy
- Authorised Trader
bassboy could you design a box and show me what a custom box would look like that would make it louder than what it is now?
- ChrisD
