2 litre zetec
8 posts • Page 1 of 1
2 litre zetec
Does anyone have a solution to the problem of fitting the 2 litre MAF to the 1.6 hose? The diameter of the 1.6 MAF compared to the 2 litre MAF is smaller, so i cannot attach the rubber hose as the diameter is to small. Would a K & N kit (the bannana shaped plastic pipe coming from the TB to the MAF) off an RS1800 fit right on to the 2 litre MAF or not?
- trustzetec16v
i know the rs1800 maf and 1.6 maff fit the same hoses. the 1.6 just has smaller hole in the centre but is exactly the same size unit.
- Sunil_FiestaRS_16V
hose
Do they have that in stock? So i'd just ask for a 50 cm length of hose, reduced from 3 inches to 2 inches?
- trustzetec16v
Ive just got some reducers from burtons the other day.
What i'm doing is taking an ERST crossover pipe from the 2L throttle body via 76-60 reducer. From the crossover pipe to the MAF via a 60mm straight hump joiner. Then the k+n staight onto the MAF. Dont know if the MAF will work properly with the k+n so close but we'll see.
- LiamMc
I think PhilSi has K&N pipe but i think ti only fits properly at one end. Perhaps easier to get somethign made up than fart around restricting the airflow though adaptors ?
Nothing to see here...
- andymac
- Elite Pie Master
Re: 2 litre zetec
Oh please please let me know if you find an easy solution. I f***** around for ages looking for a hose to do the job. You need a reucing hose from a 75 bore at one end (MAF) to 65 at other end.
I never found a good solution and ended up going to a hose warehouse and used 2 hoses of different bore but that could be stuffed inside each other if you see what I mean.
I am still looking for a neat answer but what I have does work.
If you PM me i can send you a dig pic of what I did
IT WAS A FIESTA--UNTIL--THE ULTIMATE FEZ BODY KIT!!!
QUANTUM H4--2.0 ZETEC POWER--ALL I WANT FOR CHRISTMAS IS A NOS KIT
- paulbaker
