2 ltr Throttle Body
Postby timb551 on Tue May 15, 2001 4:40 pm
Could someone help me. I want to put an uprated TB (prob Mondeo one) on my 16v XR2i. Has anyone got any literature or knbow of any website which explain exactly how to do this. Cheers in anticipation
timb551
Postby Andy_XR2i on Tue May 15, 2001 6:11 pm
try here mate...
http://www.xr2i16v.co.uk/
It's under engine and mods or something. Although where nomad's on about machining down the spindle to fit the throttle cable carrier I did the reverse and drilled out the plastic throttle cable carrier slightly, just a bit cheaper :wink: As far as I can see there's no (big) difference whichever route you take as long as you do it properly.
_________________
<!-- BBCode Start --><A HREF="http://www.shavers.co.uk/xr2i/" TARGET="_blank">www.shavers.co.uk/xr2i/</A><!-- BBCode End -->
<font size=-1>[ This Message was edited by: Andy_XR2i on 2001-05-15 18:16 ]</font>
Andy_XR2i
Postby Excursion on Tue May 15, 2001 10:00 pm
I GOT A NICE 16K ENGINE ON SAT AND THE T/B IS FOR SALE COS I ALLREADY GOT SOME.
£45 AS NEW
Postby Kat on Thu May 17, 2001 7:23 pm
Can someone tell me about throttle bodies.. as I want to make my 16v faster.. what do they do and how much????
Kat
Postby snake on Fri May 18, 2001 12:28 am
About £1600 for luminitions kit, old inlet system, manifold etc is dumped and you get 2x throttle bodies each with 2 chokes to supply each cylinder. Each have an injector. Same as DCOE carbs but more accurate fueling.. Obviously you get all the electronic gizmos to control the injectors which utilises your crank sensor.. Definatly worth the money if you`ve got it. Most people go with carbs as you can pick them up cheap, but as you need the engine to be able to pass the emmisions test this is not an option..
snake
Trainee Burger Flipper
Your car: ford
