2L zetec being slow....
15 posts • Page 1 of 1
Any ideals why ? Im running 2L maf ecu and tb and a 1.6 gear box.. also the car kinda whines on high revs and feels like its restricting big time?
One of you zetec Boyz must know!
P.s any1 convoying it to FITP from southwest?
- unknown_user
- chumkila
- Dirty Post Whore!
Well thats the problem i dont know where from. i mean above 5 grand slightly at 4 n half.. seems that the noise is making it slower... hard to describe the noise kinda as if the manifold is screaming? or a joint is blowing only under high load.. but im not sure that that would lose me so much power? still the noise is worrying i dont think the noise is engine related as the engine sounds sweet as....
- unknown_user
i did think that however.. the gearbox is not reaching its max.. with my old engine it would do say 60 in 2nd, and now the whine starts before 50.. so i kinda ruled that one out? difficult this one! im really am stuck!
- unknown_user
Ian i also thought g/box first thing as soon as i read that.
When was the last time the engine was serviced?? Also how old are the belts??
- chumkila
- Dirty Post Whore!
engine was serviced the other day at the same tiome i had a new cam belt... well the noise is still there out of gear but not as bad..
- unknown_user
what flywheel did they use?
and clutch for that matter
the mondeo it came from wasnt an automatic was it???
- fiesta_fras
- Elite Poser
it wassunt an automatic mate, i used a brand new fiesta clutch and my fiesta flywheel and box... ecu code is DESK which aint an automatic ecu either....
- unknown_user
Aren't the 1600 cats too restrictive?
You will need the 1800 inlet and exhaust manifolds to get full power to the best of my knowledge.
If a garage carried out the work, take the car back to them and demand they sort it out asap!
A STAR test might reveal some faults.
Check the oil level in your gearbox. Also check your brakes aren't binding.
Also make sure you are have the 1800 Zetec injectors (engineering code 928F 9F593 B1C - I don't know where on the injector it will be stamped though) as the 1600 ones don't seem to flow enough fuel ...?
I'm still waiting for you to get me the engineering numbers off all the parts I asked you to in your other post
Al
Al
- Project
- fiftyoneCL
Ok
I have all the numbers for you mate there at home i have the ecu MAF numbers i cant get the TB ones... if i e-mail them to you can u look for me?
- unknown_user
Ah, the whine will be the new cambelt. My Mondeo sounded dog awful for about 5K miles after it was changed.
- grahamb
u recon? but it dunt seem to wanna pull though? kinda giving up and i dont want to give it any throttle cuz of the whine? but the bottom end power seems ok.. this is a tuff one!
- unknown_user
on mine the manifolds matched up with the head, bore size wise... as the gaskets showed... i might of been lucky tho...
as for the injectors , ive heard the 1.4 zetec injectors flow enough for the 2.0 .. so not sure if the 1.6 ones would or not.. as all 1.6 stuff seams to be pants lol
also when i had the cat on for the MOT i can say it felt hardly different.. maybee with it on it had abit more torque but didnt rev as much.. but not so u'd be crying about it lol
I defo recomend a star test
- Phil Si
Car: 2000 BMW 330 Ci
yea looks like my only option i [ERRR]! just gonna go try my 1.6 ecu then if thats not it dare i say it GARAGE! for a star test or maybe a rolling road (bristol interpole).
- unknown_user
