2Ltr Auto ECU EDIS4
18 posts • Page 1 of 1
2Ltr Auto ECU EDIS4
Ok i have just ibought a 2ltr zetec from an Auto it has this EDIS module, But am i right in thinking if i get a normal ECU (i have one with DESK code) and plug that in and use my 1.6 Zetec Si loom i wont have to worry about using the Mondeo loom and EDIS module??
I think Paul Baker said this was possible but im not sure... Check your PM's Paul!
Thanks for your help!
- unknown_user
Re: 2Ltr Auto ECU EDIS4
You have PM m8 but for anyone else that has got a 2.0 from an Auto.
Use standard Si Loom and get your mits on a 2.0 Manual ECU (DO NOT ATTEMPT TO USE THE AUTO ECU) DEEP is one that I know works well. JUst plug the ECU in place of the Si one and all will be well.
IT WAS A FIESTA--UNTIL--THE ULTIMATE FEZ BODY KIT!!!
QUANTUM H4--2.0 ZETEC POWER--ALL I WANT FOR CHRISTMAS IS A NOS KIT
- paulbaker
i used deep and it was crap. try before u buy. im stickin [ERRR] my 1.6 ecu (guru) as it has excellent throttle response and is rapid compared with wen i used 2.0 ecu.
"Put your hands up mother stickers, this is a f**k up!"
- Pop
They are zippy with the 1600 ECu but ultiamtely a lot slower. hey run much rougher too.
I ran mine with a Mondeo Si ECU, it has a sportier map with much more midrange. I have forgoten the code. It was something funny.
I'd be careful if i wer u m8. The 1.6 ecu will be underfuelling across a lot of the range. I run a DEEP and it runs perfectly and no-one can convince me that an ignition and fuelling map for a 1.6 engine is right for a 2l.
I'd suspect that you had a fault in the ecu you used you could well end up damaging your motor contnually running a 2l on a 1.6 ecu.
- paulbaker
SILLY ME PRESSED THE SUBMIT BUTTON TWICE!!!
- paulbaker
Yeah where it says BLIP. By the way BLIP is a 1.8 Zetec ECU
Mondeo 1.8 litre 16 Valve 93 on Ford EECIV 93BB12A650BC 5029657 XEF3BBBC
BLIP 7145618
For a 2.0 you need either DEEP, DEWY or DESK
BLIP 7145618
- paulbaker
Tell em from me they lied and don't know what the f*** they are talking aboot
- paulbaker
I wont be forget that, Pauls already said and sent a email with pics etc !
i just been strippin my 1.6 down all i need now is the crane! Btw do u guys split the engine from the block then remove the engine or do it all connected?
im removing from the top...
I got an ECU with the code DESK from a mondeo Si not bad £16 for ebay ! a tad less than the £75 breakers yard wanted...
- unknown_user
use crane to drop engine down.
use crane to lift car up
drag out engine
ok, we had the engine on a lil trolley, but have done it a cpl of times without now too.
easy as pie
drag out engine
easy as pie
Mark.
v4 in the build...
v4 in the build...
- XR2-40
