2ltr engine conversion----
24 posts • Page 1 of 1
okay just after a little help. i have a 1991 ford fiesta mk3 with a 1.6S engine in it. It is not an Si engine or xr2i. I havent seen many of these engines before. I thought it was a xr2 engine to begin with. Quite confused me to be honest. Anyway im going to put a 2ltr mondeo engine in it very shorty but before i do so i just need to know a few things... :-
- do i need to change teh wiring loom
-what else do i need to do diferently to my engine conversion as apose to converting from an Si engine.
-Also my car has no power steering, will this affect the engine conversion?
Any help would be greatly appreciated
Cheers Tom
Cheers Tom
- wakeboardtom
- knuckles
- Your car: Fiesta Rs turbo
That guide probably won't help as you don't have injection, therefore you probably only have a really simple car loom which will need changing to a 16v MK3 one (ideally). This has all the wires for injection stuff and the extra wire to the fuse box as used by cars with a cat fitted.
- Smo
knuckles :he has got a 1.6 cvh ...
That guide is as close as it gets for now
Sorry I didn't mean to suggest you had given him useless information or anything , just thought I would point out that it's very unlikely he has a full injection loom in there. With his car, it requires just as much work as my 1.1 carb job did (Although that was far from difficult )
(I have no reason to post that smiley, but I felt like it )
- Smo
- Gmc
haha
Well i thought it would be harder to do than iff it was a normal si engine.
What would you lot do if u were me then, how would you get it done?
I cant do it myself as i have not got the tools or even the knowledge. I wouldnt know were to start! So do i pay a garage to do it or what??
I just want a 2 ltr fez lol
- wakeboardtom
Is there a Idiots guide to converting a 1.6s to 2 ltr?
i wish only thing is i like everything else about my car. only thing left for me to do to get it how i want is this damn engine conversion
Maybe someone on here would want some extra cash.... something to do in the weeknights lol i know its a longshot but.... iff i had the know how and kneeded the cash i may consider it....
- wakeboardtom
Doing a engine change is stressful enough. Let alone doing someone elses conversion.
Your looking at at least £1000 for the 2.0 ltr engine with everything you need. That would be a basic conversion as well.
Its all manual labour involved. I recomend you pull your finger out and start to learn about engines like i did. All i did was buy 2 haynes manuals, got some basic tools and started doing little bits myself. Once you learn how to use a spanner your half way there mate ....
Have a good read through that guide and think about your next move.
- knuckles
Looks like the best way really. I would really like to learn about it all anyways....
Haynes manual it is
Thanks for the advice knuckles
Haynes manual it is
- wakeboardtom
No problem
I started on my 1.1 doing the spark plugs , ignition leads, battery etc. Then on my xr2i i got a bit more adventurous , changed the oil/filter, changed the shocks and springs, Renewed the brake pads & brake discs. Then went onto replacing the whole engine.
All from reading one book
- knuckles
i must say them haynes manuals are very good arnet they. My car is on page 6 of the Max haynes manual too
- wakeboardtom
I have a guide on my site, its ment for a 1.6 SI but the most of it you can use, perhaps seek that other guide on here for the wiring changes etc
http://www.teamford.co.uk/webpage/fiest ... ersion.htm
If you cant do it yourself then it looks like you'll have to do without unless you dont mind spending major £££
- Dazza
knuckles :No garage will do such a conversion - too long winded process.
Thats not entirely true, theres a garage near me called Fiesta centre, they specialise in mk1,2,3 fiestas mainly and i think they would be able to do a 2.0lt fiesta conversion.
They are putting my 1.6 XR2i engine in my mint 1.1 fiesta at a cost of only £400.
They are based near Norwich.
if you live close enough it might be worth ringing and asking them
http://www.fiesta-centre.co.uk
- fezzapower
sorry i worded that wrong, £400 is what they will charge to do an entire conversion, including engine, gear box and clutch etc.
- fezzapower
knuckles :All i did was buy 2 haynes manuals, got some basic tools and started doing little bits myself. Once you learn how to use a spanner your half way there mate ....
I went and sold my Haynes manual for my mk3 and I'm gonna be buying one in the New Year. nutsack!
- Choosey
- If only I had an RS1800....
- Your car: 2021 Jeep Wrangler
