2ltr zetec engine package, throttle bodies, ecu, good spec
2 posts • Page 1 of 1
time has come to get rid of my first car, its a highly modified mk3 fiesta.
built over many years and has been a labour of love and an awesome learning curve. but i moved on a few years ago and its time to start letting bits go, i drove it to rotterdam in 2012 for a show and been layed up since apart from going round the block a couple of times a year.
main part up for grabs is the engine and running gear, perfect for any retro ford or hotrod or kitcar
looking for £800 ono, all in as follows
engine;
2 litre 16v zetec
rebuilt 2011 with all new gaskets, seals ect
re-honed bores
lightenened and balanced pistons, rods, clutch cover and crank. ( by autosprint bham)
shot peened rods and crank
lightened and balanced flywheel (by autosprint bham)
uprated clutch
suzuki gsxr1000 42mm throttle bodies
focus st inlet manifold
customised focus st fuelrail
Focus st170 high flow injectors
obx race manifold
Obx down pipe with decatted silencer
powerflow full custom stainless exhaust with de cat
uprated multi layer head gasket
Splitfire spark plugs
Genuine ford motorsport leads
rs1800 extra engine mount
autosprint super fast road cams max lift and 286 degrees duration inc new followers
weber adjustable fuel pressure regulator
burton power heavy duty cambelt
couple of thousand mile new starter motor and high output alternator.
5 speed standard gearbox.
management:
self built megasquirt v2.2 ecu, fully reprogram able and supports features such as nitrous control, lambda control
, launch, traction control ect ect
innovate lc-1 wideband lambda sensor
in car laptop with megatune software will be included in the sale.
extras included with sale:
Uprated cosworth high flow fse fuel pump
Self built oil catch tank
polished rocker cover and powder coated parts
required engine loom.
anything else needed that is on the car is yours to have if needed (radiator, mounts ect ect)
the engine is still on a base map as it was only just rebuilt by the time i stopped using it, starts and runs perfect and anyone interested in the engine is welcome to come see it running before purchase.
thanks anthony
engine;
2 litre 16v zetec
re-honed bores
uprated clutch
obx race manifold
management:
thanks anthony
- ant pittaway
