3.5 Mirror
Postby Tucker on Mon Dec 17, 2001 10:27 am
What does it look like and what is it like to fit ?
Tucker
Postby chumkila on Mon Dec 17, 2001 11:27 am
They look like this:
And are very easy to fit as they are a straight swap for your standard Mk3 ones. All you may need to do is file the hole alittle to make the new adjuster fit through. Simple.
:wink:
Postby Phil Si on Mon Dec 17, 2001 11:44 am
yeah u need a file to make the hole from "o" to "O" any one know what type to use? :rolleyes:
que,.. bad sick jokes....
LOL :lol:
How's my moderating? Call 0800-U-R-BANNED
Phil Si
Crack Smoker Of The Year 1999
Car: 2000 BMW 330 Ci
Postby elm_us on Mon Dec 17, 2001 11:46 am
:lol: :lol: :lol: :lol: :lol:
elm_us
RIP 1983-2004
RIP 1983-2004
Postby Tucker on Mon Dec 17, 2001 11:47 am
Cheers mate :grin:
Where is the best place to get them from?
I like the motor is it yours?
Tucker
Postby Tucker on Mon Dec 17, 2001 11:50 am
Trust you phil :lol:
Tucker
Postby Phil Si on Mon Dec 17, 2001 11:58 am
:rolleyes: whaaaaa..? :lol:
Phil Si
Postby packers on Wed Dec 19, 2001 8:15 am
Just fitted mine the other day so trust me it depends on what reg (or what doors your car has) ive got a mk3 Hreg 1.1 and they were a little more difficult to fit, you have to make the hole where the adjuster arm goes through a lot wider. If your cars a mk3.5 i think the holes are in the rite place. If not you make it From this:
___________
(___________)
to Sorta this
___xXXXXXXXX
(___________)X
......xXXXXXXXX
(CUT OUT WHERE ALL THE 'X's ARE)
using a file will a long time, and if you got a dremel or somthing like that you gonna need loads of blades. I got that bored with filing it i used a drill to drill loads of holes hext to each other then bent em using a screwdriver, riped the points off with pliers and filed the sharp parts down. Not a pretty resuly but who cares...its covered up.
If you can get one of them sideways cutting driil bits (like on tv) i imagine they would be great if they work!!
If you got a doors like mine you will also need to drill a third hole (above the hole above) for the top securing arm to be bolted thorough to the car....a holes drilled on the outer skin but its big so you need to guess the position iof the interal one and make the hole bigger until you find fits (if you drill it to big dont worry just slap a big washer on it like i did, problem solved.......lol.
just making you aware of any probs you mite have before you start.......
if its like mine was its not gonna be a 20min job your gonna be looking at about 3hours maybe.........so dont let it go dark outside like i did and ended up using a torch to see what i was doin to finish it...lol.
although u may be luck and have the doors already drilled for you.
Hope it helps.....tell us all how you go on.
_________________
Image"Fonzarelli in the house..heeyyy!" Image
<!-- BBCode Start --><A HREF="http://www.with4wheels.co.uk" TARGET="_blank">www.with4wheels.co.uk</A><!-- BBCode End -->
<font size=-1>[ This Message was edited by: packers1982 on 2001-12-19 07:26 ]</font>
packers
Postby xrsi on Wed Dec 19, 2001 8:39 am
just fitted mine, not to much bother - apart from the fact i had to set about a freshly painted car with a file!!!!
Took just over an hour and made alot of noise!!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby chumkila on Wed Dec 19, 2001 8:41 am
:lol: @Phil!
Naah the car's not mine, its Ian FRST's. (cheers for the pic Ian) :grin:
Funnily and very weirdly the Mk3.5 mirrors were a STRAIGHT swap on my doors!!! No filing or messing about!! :grin: :grin:
Postby Tucker on Wed Dec 19, 2001 9:21 am
Packer1982 -Well it sounds like you had a bit of trouble.
Mines a H reg 1990 mk3 2i so I hope it will be a stright forward job
not that I have got them yet. but when I do :grin:
Tucker
Postby chumkila on Wed Dec 19, 2001 9:37 am
i expect you will have to do the filing job but it aint hard at all. i was just lucky as my cars a MUTANT!!! :grin:
Postby Tucker on Wed Dec 19, 2001 9:45 am
chumkila just like your sig :grin:
Tucker
Postby chumkila on Wed Dec 19, 2001 11:07 am
:grin: :grin:
Postby Tucker on Wed Dec 19, 2001 11:21 am
:lol: :lol:
Tucker
Postby Choosey on Wed Dec 19, 2001 2:30 pm
if the car is an mk3.5 then it'll have the mk3.5 mirrors in the first place! :lol:
Choosey
If only I had an RS1800....
Your car: 2021 Jeep Wrangler
Postby chumkila on Wed Dec 19, 2001 3:27 pm
:grin: :grin:
Postby Tucker on Thu Dec 20, 2001 4:03 am
I just thought it was a MK3 so how do i tell the diff apart from the mirrors?
Tucker
Postby xrsi on Thu Dec 20, 2001 6:03 am
quite a few things - revised floor pan, black plastic interior trim, flap over fuel filler, no lines pressed into bootlid! MIRRORS :razz:
quite a few other smaller more suttle things but i can be arsed to go into it all!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby Tucker on Thu Dec 20, 2001 6:05 am
Nope mines not a 3.5 then, just a poor old mk3 :sad:
Tucker
Postby packers on Thu Dec 20, 2001 8:37 am
How do you know it hasnt had replacment doors in its time.
packers
Postby chumkila on Thu Dec 20, 2001 12:52 pm
I think you can tell when u see it. :wink:
Postby MadcatCraig on Thu Dec 20, 2001 2:49 pm
They not a straight swop ! you have to make hole bigger for adjuster thingy to get thru !
MadcatCraig
BANNED SELLER
Postby chumkila on Thu Dec 20, 2001 3:02 pm
yea USUALLY you do but as i was sayin uptop mine WERE!! :eek: weird plain weird!!
Postby Tucker on Fri Dec 21, 2001 4:25 am
Chumkila iits not werid plan werid just chuffed :grin:
Tucker
Postby Tom SX on Fri Dec 21, 2001 8:22 am
you might find like i did that my mk 3 has a mk 3.5 drivers door, makes it easier :wink:
Tom SX
Your car: A big German gaymobile
Postby chumkila on Fri Dec 21, 2001 1:32 pm
well looks like BOTH my doors are Mk3.5's! :grin:
Postby Project on Fri Dec 21, 2001 3:46 pm
U sure Tom??? :???:
Project
fiftyoneCL
fiftyoneCL
Postby Choosey on Sun Dec 23, 2001 6:33 pm
On 2001-12-20 07:37, packers1982 wrote:
cos it should have a full service history.if its got replacement doors......WHY? in a smash maybe?an if it got replacement doors wouldnt it have the mirrors on it?an if its got mk3.5 doors theres no problem is there?!or you could always buy a mk3.5 in the first place like me! :rolleyes:
dont want to sound mean tho matey!
good point.didnt think of that. :smile:
Choosey
Postby chumkila on Sun Dec 23, 2001 6:38 pm
me car was owned by a Ford dealership in Birmingham and i'm the 2nd owner. Had it nearly 3yrs. :grin:
