35mm lower on 17s si
Postby tedders on Fri Jan 04, 2002 3:58 pm
how hard will it be to do this? and would i need to do? cheers
tedders
Postby chumkila on Fri Jan 04, 2002 4:22 pm
not hard to do just have to be willing to part with the money to get the job done.
first read this:
http://www.fiestaturbo.com/content.php?page=fitting17s
you may be able to get away with uprated shocks and springs but there is no better way to go than getting coilovers. but again these are pretty expensive. looking at anything between £400 - £800 depending on your choice.
secondly you will need to heavily mod your arches both inner and out. this will set u back about £250.
if your up for it, then go for it!
:grin: :grin:
_________________
*chumkila* RS1800
++BiG PiMpIn BaBy++
<font size=-1>[ This Message was edited by: chumkila on 2002-01-04 15:24 ]</font>
Postby tedders on Fri Jan 04, 2002 4:32 pm
i have tryed a 17 wheel on but my car is not lowerd it misses the cup so will i be able to get away with out changing the shocks just put springs on. What innner arch mods will i need (rear or front)
tedders
Postby chumkila on Fri Jan 04, 2002 4:50 pm
having just one wheel on, and having 4 wheels on and driving to totally different ballgame. the rears are the shocks that are prone to being hit by the alloys.
but yes you could get away with just springs if ur lucky.
well most ppl will junk the inner arch linings and some will go the extra mile and re-attached them as they are screwed, abit higher up the inner arch. depends how bad they catch.
Postby icecool on Sun Jan 06, 2002 8:05 pm
With the Si you don't need to alter the shocks to run 17's. As Chumkilla said you need to remove the arch liners and the arches need to be ground back so you may have to look at rs arch trims to cover the gap.
Don't go any lower than 35mm and if you intend to go for shocks as well then your only choice is coilovers.
Coming soon!!!!
icecool
Postby Thumbs on Mon Jan 07, 2002 6:14 pm
Why is your only choice coilovers ????
Thumbs
