35mm or 60mm
32 posts • Page 1 of 1
35mm or 60mm
Have been wondering for ages if to go for a 35mm or 60mm drop.
Can ppl tell me the bad points about both. I'll be running 15" wheels with 195/45/R15 tyres.
- Escort Cos
60 mm looks wicked but if ur car is ur daily runner and u take ppl init alot then i wud go with 35mm. im running a full gmax kit dropped 35mm on 15/195/45
- Sunil_FiestaRS_16V
Sunil_FiestaRS_16V :60 mm looks wicked but if ur car is ur daily runner and u take ppl init alot then i wud go with 35mm. im running a full gmax kit dropped 35mm on 15/195/45
spoken like a wiseman. car also looks good.
- chumkila
- Dirty Post Whore!
Mixon, Whats your ride and hadling like? When do you get scrabbage etc?
What kit do u have and how much was it?
Your wheels are 15's, With what size tyres?
Questioning Over!
Questioning Over!
SI is -60+ on GMAX shocks and SPAX springs. 195/45/15 and arches cut out for 17s. 6ppl in the car the other day and no scrubbing. Only problem was once everyone was in the car it was too low to shut the passenger door, it got stuck on the path
2i is -40mm on GMAX shocks and springs with 195/45/15. Scrubbs with four ppl in the car
- MaXsteri
mines lowered 35mm on standard shocks, 195/50/15's and rears scrubb with no people in the car!! Only over sharp bump or speed hump too fast.
I get absolutley no scrubbage at the front under any condtions, cos i fitted a frst steering rack.
I have problems at back cos of me low offset (so they stick out a lot) even though i've ground about 3/4" off the wheel arches.
Do you think upgrading to gmax shortened shocks and springs (35mm) will help it ground out less at the back?
- Brian
Only ever had 2 problems with -60+
1 = Cant get up onto the MOT station. Had to make the slope more gradual
2 = Was following a tractor down a country lane at <5MPH and heard random scraping, so got out to have a look and chassis had literally 1mm clearance from the ground Worse than that tho, it had caught on a cow turd and had dragged it all over the underside of the car I blame it on Maff SI's fat arse being in the car Needless to say i wont be going down that road again
- MaXsteri
Max M4X WW :Mixon, Whats your ride and hadling like? When do you get scrabbage etc?
Questioning Over!
Standard shocks (new) with poly bushes all round, PI springs -60, but two coils cut off the back
Tyres 195/45/15's no rubbage except full lock to the right
- JamieFRST
- Keep It Tidy
depends what bumpers you have or are getting, Mine would easily go down to 60mm on the 1.1 bumpers, but I have animal bumpers to be fitted so 60mm on them would be a pain. So if you want bigger bumpers like animal/cossie on any big spliters then only go 35mm.
- Percy!
- Your car: Citreon
If you only get rubbing one way, it is likely your tracking is out a bit
- Brian
go 60 mate...especially if u want the car to handle like a go kart and DONT have bumpy roads where u live
then again, saying that, my Scirocco was lowered 105mm all round, sitting on 7.5"x15" rims with an et25 offset!!!! no scrubbing whatsoever!! oh and i live probably in the worst area for bumps and dodgy roads got stuck over speed bumps twice but thats not bad considering i can JUST about make it over most of them here
bassboy
bassboy
- bassboy
- Authorised Trader
Went for 35mm in the end as Xfactor was selling a cheap gmax kit.
Where I live the roads are lousey aswell and I can't be dealing to slow down at every bump.
- Escort Cos
- Phil Si
Car: 2000 BMW 330 Ci
my car was originally 60mm on springs and scrubbed like a Bic™ everywhere and handled badly.
It is now on G-max 35mm shocks and springs with no scrubbage at all and handles well (although the front and rear strut braces probably make a big difference).
When it was lowered 60mm I took out the exhaust mid section on a bit of rough road. It broke into two parts!!!!!
- warrenpenalver
Was just guna ask how u got ur arse end down.Mines exactly the same m8,just rubs on the right on full lock.-60 [ERRR] 195/45/15s.mixon :Max M4X WW :Mixon, Whats your ride and hadling like? When do you get scrabbage etc?
Questioning Over!
- devildamo
