37K Ford Fiesta : Member's Gallery - Page 5 | Fiesta Forums
37K Ford Fiesta
Re: 37K Ford Fiesta
Postby xr2irhys on Mon Jul 04, 2011 7:40 pm
started cleaning rust spots up from inside the wheel arch
this is how the rear looked after i gave it a degrease :wink: pretty tidy apart from bottom half a bit crusty in places , so will be repaired.
xr2irhys
Car: 1996 Ford Fiesta Classic
Re: 37K Ford Fiesta
Postby xr2irhys on Thu Jul 14, 2011 10:14 am
Bump :)
xr2irhys
Re: 37K Ford Fiesta
Postby EUFez on Thu Jul 14, 2011 9:28 pm
BumpBTTSpam
EUFez
Re: 37K Ford Fiesta
Postby xr2irhys on Tue Jul 19, 2011 9:17 pm
got a new brake pipe made up today for it as old one would not undo with out twisting the pipe as connector siezed on , and sprayed it in green to look simlar to the orginal ford brake pipes on there now :)
also been sorting inside the wheel arches removing rust
( water drops on brake pipe pic)
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Tue Jul 19, 2011 9:52 pm
Good work, keep it up :)
Re: 37K Ford Fiesta
Postby Michael! on Tue Jul 19, 2011 10:15 pm
its good that you're putting all this effort into keeping it standard rhys
good job mate!
ft-com-members-map-vt190192/
Michael!
Re: 37K Ford Fiesta
Postby xr2irhys on Tue Jul 19, 2011 10:32 pm
just look forward to driving it ! the gears feel so close together etc when moving the gear stick , its going to be a dream to drive , look forward taking it to some ford shows :)
xr2irhys
Re: 37K Ford Fiesta
Postby Michael! on Tue Jul 19, 2011 10:34 pm
ford fair?
Michael!
Re: 37K Ford Fiesta
Postby xr2irhys on Tue Jul 19, 2011 11:35 pm
Michael! :ford fair?
behave................................ you honestly think it will be done this year :lol:
xr2irhys
Re: 37K Ford Fiesta
Postby Michael! on Tue Jul 19, 2011 11:49 pm
i wanted to have mine done, but now theres no chance haha
Michael!
Re: 37K Ford Fiesta
Postby xr2irhys on Tue Jul 26, 2011 10:05 am
Got a spot weld cutter , spot weld drill bit , and new front valance on the way :)
xr2irhys
Re: 37K Ford Fiesta
Postby xr2irhys on Thu Jul 28, 2011 1:46 pm
old valance is now removed :)
i noticed the spot welds on the inner pannel that the lower part of the valance joins to was very near the edge! am i best to reposition them ? removing was a bit of a pain as right on the edge too
panel removed
old rusty pannel
started to clean up the metal
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Thu Jul 28, 2011 2:47 pm
I recommend bonding on the new panel. Just put a small tack weld on each leading edge by the wings then use sikaflex or similar for the rest, it will cut down the chance of future rust.
Re: 37K Ford Fiesta
Postby xr2irhys on Thu Jul 28, 2011 3:22 pm
Excursion :I recommend bonding on the new panel. Just put a small tack weld on each leading edge by the wings then use sikaflex or similar for the rest, it will cut down the chance of future rust.
sounds an idea, bonded even at the bottom holey bit ? then im geussing seam seal it in still as normal :)
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Thu Jul 28, 2011 3:42 pm
xr2irhys :sounds an idea, bonded even at the bottom holey bit ? then im geussing seam seal it in still as normal :)
Put a tack either side on the leading edge where the factory sealer is usually applied - one at the top and one at the bottom, then a few tacks underneath. Seal the lapped joints :)
Re: 37K Ford Fiesta
Postby xr2irhys on Sun Jul 31, 2011 9:19 pm
replacement wing for driver side on order :)
xr2irhys
Re: 37K Ford Fiesta
Postby xr2irhys on Mon Aug 01, 2011 3:20 pm
any one got any tips for fitting and shaping the brake pipe ,with out scraping the paint off each time :( going to have to repaint it now,
thinking repaint it them masking tape it all , and then fit it
been busy again with the car , other passengers side wing is off , and been cleaning up the drivers side wheel arch a bit more today , slowly looking rust free now :)
xr2irhys
Re: 37K Ford Fiesta
Postby xr2irhys on Mon Aug 01, 2011 6:26 pm
few pictures of the inner wheel arch today , been cleaning it up more , still a bit to do , but its getting there :)
( bare metal is covered in grease to prevent rusting ) :)
xr2irhys
Re: 37K Ford Fiesta
Postby xr2irhys on Tue Aug 02, 2011 10:08 am
Oooo look a delivery !! :)
and the wing offered in place
Looks a pretty good fit to me , nice pannel gap by the door shut etc , what we all rekon :P
xr2irhys
Re: 37K Ford Fiesta
Postby xr2irhys on Tue Aug 02, 2011 12:54 pm
Been playing about with the wing , trying to get the pannel gap right , i noticed it sticks out a little futher than the door pannels at the bottom?
other than that , all the other bad stories ive heard about pattern parts , its a bloody good fit 8)
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Wed Aug 03, 2011 11:38 am
You have to grind a bit of the rear of the wing away, the wings aren't too bad really :)
Re: 37K Ford Fiesta
Postby xr2irhys on Wed Aug 03, 2011 12:26 pm
Excursion :You have to grind a bit of the rear of the wing away, the wings aren't too bad really :)
yep a fairly good fit , and you mean grind away where it bolts up ? yeah thought that area was the problem........ what about getting the swag line straight?
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Wed Aug 03, 2011 1:55 pm
xr2irhys :yep a fairly good fit , and you mean grind away where it bolts up ? yeah thought that area was the problem........ what about getting the swag line straight?
You need to raise the wing slightly, it's hanging a little low in your photos. The pattern wings will never fit 100% so it's a case of getting the best compromise overall.
I've fitted them in the past and had to make quite a few minor adjustments, including up near the scuttle panle and inside the wing near the a pillar. You can get a pretty convincing result with a bit of work.
Re: 37K Ford Fiesta
Postby xr2irhys on Wed Aug 03, 2011 4:06 pm
yep thats what i ment Hanging a bit low , i cant seem to move it up any more ? only way i can think of doing it putting the wing on a hardge edge and nocking the inner wing bit where it welds onto , so it lifts the rest up?
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Wed Aug 03, 2011 4:44 pm
xr2irhys :yep thats what i ment Hanging a bit low , i cant seem to move it up any more ? only way i can think of doing it putting the wing on a hardge edge and nocking the inner wing bit where it welds onto , so it lifts the rest up?
You just need to see where it's binding and grind it away. Don't touch the car, it's all 'factory', it's the wing that's the problem.
Re: 37K Ford Fiesta
Postby xr2irhys on Wed Aug 03, 2011 11:35 pm
ok great help thanks , must admit though i took the passenger side off with out correct spot weld drill bits , so think bent the inner wing a little! just will have to play about till get it right :)
oh and this forum used to be so busy.. whats happened :(
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Thu Aug 04, 2011 10:26 am
xr2irhys :ok great help thanks , must admit though i took the passenger side off with out correct spot weld drill bits , so think bent the inner wing a little! just will have to play about till get it right :)
It's a few things really;
- Most of the Mk3's have rotted away
- A lot of those that didn't were sacrificed in the scrappage scheme
- The mk3 is now considered too old and unsafe by many parents to be a first car
- Original owners have moved on
There's only a few people like us who are crazy enough to bother with them :lol:
Re: 37K Ford Fiesta
Postby xr2irhys on Sun Aug 07, 2011 8:18 pm
had a play with the passenger side for a around 45 mins not long ago , and got the wing looking like this :)
also spent a bit in the employers shop today , got some of this :P
and to say what bargain i got , £18 for two liters of hammerite :)
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Sun Aug 07, 2011 8:23 pm
Nearly there! It needs pulling in a little so it sits more flush with the door, but you're 95% there :D
Re: 37K Ford Fiesta
Postby xr2irhys on Sun Aug 07, 2011 8:32 pm
Excursion :Nearly there! It needs pulling in a little so it sits more flush with the door, but you're 95% there :D
this is the other side , not the drivers side as previosly posted up, what bit you mean need pulling in , as in the door gap or whole wing needs to "push in closer "
xr2irhys
Re: 37K Ford Fiesta
Postby Excursion on Sun Aug 07, 2011 8:39 pm
xr2irhys :
Yes the whole wing needs to sit closer to the car, the panel gap is already good.
Re: 37K Ford Fiesta
Postby xr2irhys on Sat Aug 13, 2011 4:09 pm
thinking of fitting an rs Acessory kit :D
xr2irhys
Re: 37K Ford Fiesta
Postby rsturbonutter on Tue Aug 16, 2011 11:00 am
xr2irhys :thinking of fitting an rs Acessory kit :D
there's one for sale on ebay right now brand new will find it an post the link now fella :Q :Q :Q
rsturbonutter
Your car: Fiesta RS turbo
Re: 37K Ford Fiesta
Postby rsturbonutter on Tue Aug 16, 2011 11:05 am
rsturbonutter :
here it is http://www.ebay.co.uk/itm/Rare-New-Old- ... 3a693d3ba5
rsturbonutter
Re: 37K Ford Fiesta
Postby Minstral on Tue Aug 16, 2011 5:16 pm
that is a bargain. i have a brand new rs accessory spoiler the sort like an rst fpoiler but with a lip, for sale if u you want it
Minstral
Your car: *
