37K Ford Fiesta
Re: 37K Ford Fiesta
FiestaBen :jonyb4 :it doesnt appear to be in best mechanical condition given the milage, was it mainly kept outside?
best looking part is the brake pipes
so just because it's low mileage, it's not expected to have 3 problems?
id hardly expect a snapped coil after 40k miles, my car was on 90k and had it original coils before i lowered it
just saying its odd, must have seen the wrong end of a pot hole a few times
if i were you rhys, id lower it 30mm maybe some Xr 8v alloys and a Si/Xr spoiler and it will look great
Re: 37K Ford Fiesta
Nah dont want to replicate this with any thing just want it to be a nice clean orginal fiesta ....
ive considered standard fiesta rubber spoiler for the boot lid , and possibly set of alloys in future like RS ones something ford. in 13/14 inch
- xr2irhys
Car: 1996 Ford Fiesta Classic
Re: 37K Ford Fiesta
Picked up a bargain yesterday, £2 for a full set of brand new unopened genuine Ford mud flaps Might fit them to her!
- xr2irhys
Re: 37K Ford Fiesta
They made my car rust
Re: 37K Ford Fiesta
Saw the title and thought it meant £37,000 Fiesta! Great find, looks mint.
- jimmyesh
- Your car: Yes
Re: 37K Ford Fiesta
jimmyesh :Saw the title and thought it meant £37,000 Fiesta! Great find, looks mint.
Re: 37K Ford Fiesta
jonyb4 :jimmyesh :Saw the title and thought it meant £37,000 Fiesta! Great find, looks mint.
Rs Turbo........Rebuild happening! SLOWLY
- emblem
- Your car: White 1990 Escort RST
Re: 37K Ford Fiesta
emblem :jonyb4 :jimmyesh :Saw the title and thought it meant £37,000 Fiesta! Great find, looks mint.
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
Respect for leaving alone(4now )Always good to see (very clean that one)variations of the mk3 in all spec levels,to many carved up/crushed....(make an awesome sleeper...)
- Fraggle
Re: 37K Ford Fiesta
Why did you bleed the brakes if the fluid needs changing
Re: 37K Ford Fiesta
Max M4X WW :Why did you bleed the brakes if the fluid needs changing
personally id leave it standard, but upgrade the crappy bits, central locking, electric windows, actually remote central locking, a 1.6 zetec/cvh
remote boot release, electric mirrors, just everything like that, but leave it looking standard, OEM+ at its finest
Re: 37K Ford Fiesta
Because wanted to see if bled up and was not a leak any where.... yup plan to keep it standard going to order a new front valence and repair rusted areas of the wing soon
- xr2irhys
- xr2irhys
Re: 37K Ford Fiesta
just been doing a bit more degreasing on the car wheel arches , and cleaned the one and only silver steelie on the car
now i need help from you people either...
Spray rest of steelies silver to match or find new silver steelies with no trims
leave steelies as they are and use wheel trims
spray black with no trims
heres a few pics
heres a few pics
- xr2irhys
Re: 37K Ford Fiesta
unless you get a good set of trims that match the car i say paint them all silver.
if your going for trims, then paint them black
Re: 37K Ford Fiesta
any ideas why one steelie is sliver and rest are black ? looked to be orginal paint not sprayed... and couldnt find another silver one on ebay at all?
- xr2irhys
Re: 37K Ford Fiesta
i could be wrong, but i would of thought base spec (which didnt come with hub caps) would of had silver and those that did have caps came with black, so maybe the spare was silver or someone get a wheel from elsewhere somewhere along the lines
Re: 37K Ford Fiesta
Yep same as what i thought , was hoping to find a nice brand new set on ebay in silver can but can i......... lol
this should be a lovely car by the time im done with her
think i am going to do all the steelies silver to match , would hammerite paint be best for steelies?
- xr2irhys
Re: 37K Ford Fiesta
the older base spec very early mk3s had silver steels liek them (doritos i call them due to the little triangles) which had small hub caps fitted
id try to find some original mk3 trims myself and paitn them all satin black, it an be done, i have an original trim from my very first car, was a 1.1 freestyle, i can get you a pic of it if you like
Re: 37K Ford Fiesta
silver looks clean and new though , which is the look im after on the car
would took it to fitp but wont be on the road by then , so may be next year
- xr2irhys
Re: 37K Ford Fiesta
yeah hammerite will be ok, the problem is getting the rust off, and with it being silver, any little pits will show, unless you fill them but its a bit over kill for a set of rims.
i would spray them over hand paint though unless you know the hand paint is going to flow and remove the brush marks
Re: 37K Ford Fiesta
ill use the hammerite spray cans
- xr2irhys
Re: 37K Ford Fiesta
should be plenty good enough mate, just clean the rust up well
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
I love the colour, really unique. If I had your car, I'd get over rider bumpers. Slam it on coilovers, bigger engine. Basically a sleeper, keep it standard and simple. Engine upgrade etc.
But fair play to you for making it mint again, goodluck with it Rhys!
- EUFez
Re: 37K Ford Fiesta
started on the underside today , really could do with a high jack and some high axel stands but there you go we get by.... lol
what i plan to do is remove the surface rust and coroded areas of the underside of the car , and then spray over the bare metal areas with a metal zinc primer to protect the area ,
but do i use waxoyl or underseal ?
i plan to paint the underside with hammerite
or do i just get the colour hammerite i want then waxoyl over the top with clear ?
- xr2irhys
Re: 37K Ford Fiesta
ive bought some metal brush on primer which im going to use on areas that im working on , areas that are still good ill be leaving to keep fords original stuff on there as its better stuff , plus more protection with double the coats
so going to metal primer the bare metal areas that are being wire brushed, followed by " Silver grey" Hammerite paint and then waxoyl ontop for added protection
- xr2irhys
- xr2irhys
Re: 37K Ford Fiesta
Looking good mate!
- EUFez
Re: 37K Ford Fiesta
your doing great mate, but rather you than me lol
very time consuming job this, ive always out my cars off when planning on this
Re: 37K Ford Fiesta
jonyb4 :your doing great mate, but rather you than me lol
huh ive always out my cars off lol
- xr2irhys
Re: 37K Ford Fiesta
lol sorry, i always put this off on my cars, as in i never actually do the undersealing
Re: 37K Ford Fiesta
ahh you should if you want it to last keeps the rot away nicely if kept ontop of
not doing anything to the fiesta today , yesterday and today been cleaning the garden flooring up with the new pressure washer i just bought , just a cheapy halfords one but it certainly does the job
- xr2irhys
