37K Ford Fiesta
Re: 37K Ford Fiesta
- xr2irhys
Car: 1996 Ford Fiesta Classic
Re: 37K Ford Fiesta
Bump
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
its good that you're putting all this effort into keeping it standard rhys
good job mate!
good job mate!
- Michael!
Re: 37K Ford Fiesta
just look forward to driving it ! the gears feel so close together etc when moving the gear stick , its going to be a dream to drive , look forward taking it to some ford shows
- xr2irhys
Re: 37K Ford Fiesta
ford fair?
- Michael!
Re: 37K Ford Fiesta
Michael! :ford fair?
behave................................ you honestly think it will be done this year
- xr2irhys
Re: 37K Ford Fiesta
i wanted to have mine done, but now theres no chance haha
- Michael!
Re: 37K Ford Fiesta
Got a spot weld cutter , spot weld drill bit , and new front valance on the way
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
I recommend bonding on the new panel. Just put a small tack weld on each leading edge by the wings then use sikaflex or similar for the rest, it will cut down the chance of future rust.
Re: 37K Ford Fiesta
Excursion :I recommend bonding on the new panel. Just put a small tack weld on each leading edge by the wings then use sikaflex or similar for the rest, it will cut down the chance of future rust.
sounds an idea, bonded even at the bottom holey bit ? then im geussing seam seal it in still as normal
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :sounds an idea, bonded even at the bottom holey bit ? then im geussing seam seal it in still as normal
Put a tack either side on the leading edge where the factory sealer is usually applied - one at the top and one at the bottom, then a few tacks underneath. Seal the lapped joints
Re: 37K Ford Fiesta
replacement wing for driver side on order
- xr2irhys
Re: 37K Ford Fiesta
any one got any tips for fitting and shaping the brake pipe ,with out scraping the paint off each time going to have to repaint it now,
thinking repaint it them masking tape it all , and then fit it
been busy again with the car , other passengers side wing is off , and been cleaning up the drivers side wheel arch a bit more today , slowly looking rust free now
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
You have to grind a bit of the rear of the wing away, the wings aren't too bad really
Re: 37K Ford Fiesta
Excursion :You have to grind a bit of the rear of the wing away, the wings aren't too bad really
yep a fairly good fit , and you mean grind away where it bolts up ? yeah thought that area was the problem........ what about getting the swag line straight?
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :yep a fairly good fit , and you mean grind away where it bolts up ? yeah thought that area was the problem........ what about getting the swag line straight?
You need to raise the wing slightly, it's hanging a little low in your photos. The pattern wings will never fit 100% so it's a case of getting the best compromise overall.
I've fitted them in the past and had to make quite a few minor adjustments, including up near the scuttle panle and inside the wing near the a pillar. You can get a pretty convincing result with a bit of work.
Re: 37K Ford Fiesta
yep thats what i ment Hanging a bit low , i cant seem to move it up any more ? only way i can think of doing it putting the wing on a hardge edge and nocking the inner wing bit where it welds onto , so it lifts the rest up?
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :yep thats what i ment Hanging a bit low , i cant seem to move it up any more ? only way i can think of doing it putting the wing on a hardge edge and nocking the inner wing bit where it welds onto , so it lifts the rest up?
You just need to see where it's binding and grind it away. Don't touch the car, it's all 'factory', it's the wing that's the problem.
Re: 37K Ford Fiesta
ok great help thanks , must admit though i took the passenger side off with out correct spot weld drill bits , so think bent the inner wing a little! just will have to play about till get it right
oh and this forum used to be so busy.. whats happened
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :ok great help thanks , must admit though i took the passenger side off with out correct spot weld drill bits , so think bent the inner wing a little! just will have to play about till get it right
It's a few things really;
- Most of the Mk3's have rotted away
- A lot of those that didn't were sacrificed in the scrappage scheme
- The mk3 is now considered too old and unsafe by many parents to be a first car
- Original owners have moved on
There's only a few people like us who are crazy enough to bother with them
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
Nearly there! It needs pulling in a little so it sits more flush with the door, but you're 95% there
Re: 37K Ford Fiesta
Excursion :Nearly there! It needs pulling in a little so it sits more flush with the door, but you're 95% there
this is the other side , not the drivers side as previosly posted up, what bit you mean need pulling in , as in the door gap or whole wing needs to "push in closer "
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :Excursion :Nearly there! It needs pulling in a little so it sits more flush with the door, but you're 95% there
Yes the whole wing needs to sit closer to the car, the panel gap is already good.
Re: 37K Ford Fiesta
thinking of fitting an rs Acessory kit
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :thinking of fitting an rs Acessory kit
there's one for sale on ebay right now brand new will find it an post the link now fella
- rsturbonutter
- Your car: Fiesta RS turbo
Re: 37K Ford Fiesta
rsturbonutter :xr2irhys :thinking of fitting an rs Acessory kit
here it is http://www.ebay.co.uk/itm/Rare-New-Old- ... 3a693d3ba5
- rsturbonutter
Re: 37K Ford Fiesta
that is a bargain. i have a brand new rs accessory spoiler the sort like an rst fpoiler but with a lip, for sale if u you want it
- Minstral
- Your car: *
