37K Ford Fiesta
Re: 37K Ford Fiesta
the bolts are really bugging me now though , the whole original idea has gone out of my head because of it
- xr2irhys
Car: 1996 Ford Fiesta Classic
Re: 37K Ford Fiesta
Excursion :I'm using button head stainless bolts on mine. I was umming and ahhing over whether to paint the bolts or not, but in the end just settled for unpainted stainless.
got any pics
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :the bolts are really bugging me now though , the whole original idea has gone out of my head because of it
What do you mean? Don't you you like it?
Just my opinion, but I would remove the wings, refit the bolts loosely and then use some pliers to straighten up the angle of the rivnuts. I would then swap those Pan Heads for some Button Heads and use a larger diameter washer under them to spread the load to prevent paint damage.
If you don't like the Rivnut idea then you can use self tapping coach bolts: http://www.ebay.co.uk/itm/Vauxhall-Opel ... 2a0e583e18
Re: 37K Ford Fiesta
Excursion :xr2irhys :the bolts are really bugging me now though , the whole original idea has gone out of my head because of it
yeah im not a fan unforatuntly , yeah ive been thinking try a diffirent style head bolt and see how that looks , will get those rivnuts tweeked over a bit too then , i knew they wasnt straight sound advice again.
- xr2irhys
Re: 37K Ford Fiesta
yeah those bolts look better , but i just dont like the bolts at all if im honest would rather them welded on , but that aint going to happen and ive drilled the holes now so will remain bolt on.
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :yeah those bolts look better , but i just dont like the bolts at all if im honest would rather them welded on , but that aint going to happen and ive drilled the holes now so will remain bolt on.
Pretty easy to go to weld on mate, just weld up the holes on the inner wing flange and grind flat, then use the holes you've drilled in the wings to weld the panel on.
Re: 37K Ford Fiesta
Excursion :xr2irhys :yeah those bolts look better , but i just dont like the bolts at all if im honest would rather them welded on , but that aint going to happen and ive drilled the holes now so will remain bolt on.
yeah its more a case of i dont have a welder no more, and dont really know any one else
i just dont like how got bolts along the top , bolts inside etc its just not " a ford way "
interested in seing a pic of your wings bolted on if you have any?
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :i just dont like how got bolts along the top , bolts inside etc its just not " a ford way "
I'll have some next week when it's back from the Bodyshop.
All Ford models from around 2004 have bolt on wings
Re: 37K Ford Fiesta
Excursion :xr2irhys :i just dont like how got bolts along the top , bolts inside etc its just not " a ford way "
okay its not " original " then at car shows etc i can see the bolt on wings being picked up alot
- xr2irhys
Re: 37K Ford Fiesta
xr2irhys :okay its not " original " then at car shows etc i can see the bolt on wings being picked up alot
No they're definitely not the choice if you want to keep it original, but they offer a big functional improvement over original fit.
Re: 37K Ford Fiesta
Excursion :xr2irhys :okay its not " original " then at car shows etc i can see the bolt on wings being picked up alot
yeah thats right and due to me not having a welder its also quicker too. at the bottom by the valence there is faily large gaps , will the seam sealer be ok to fill those gaps? the bolts do not pull it right up tight to one another plus the pannels are not flat due to way been manufactured which also doesnt allow them to meet closely
- xr2irhys
- xr2irhys
Re: 37K Ford Fiesta
you still have the mk4 then?
is that what your plotting about in?
Re: 37K Ford Fiesta
jonyb4 :you still have the mk4 then?
nah thats scrap , i dont have a car the mk4 needed bit of welding and various other repairs , wasnt worth it
tax and mot had run out
if im paying for tax and mot , i may aswell wait and get the project car on the road
- xr2irhys
Re: 37K Ford Fiesta
true true mate, if done right, scrapping the car will pay for mot and tax
by done right i mean, stripe the cat off, take the tyres off and sell then weight the wheels in, then get the scrap company to collect it, most dont charge (here atleast)
should make over £200 that way
my mate done so with a mk6 escort with alloys albiet worth more, earned about £355 so not bad compared to about £140 for just weighing the car in
Re: 37K Ford Fiesta
jonyb4 :true true mate, if done right, scrapping the car will pay for mot and tax
yeah got loads of parts listed on ebay
- xr2irhys
Re: 37K Ford Fiesta
nah sord ebay, no one really needs mk4 parts as theyre so readily available from breakers etc
and its an encore so theres sod all on it
just use breakers and metal salvagers and you will get plenty of money
Re: 37K Ford Fiesta
cars now covered up defeating the snow and ice and wet weathers just need a half decent day to carry on
- xr2irhys
Re: 37K Ford Fiesta
you did finish the undersealing yea?
water will still find a way unless you have it drystored
Re: 37K Ford Fiesta
jonyb4 :you did finish the undersealing yea?
no not finished any bare metal greased up, shouldn't be to bad as its underneath and no water will get to the underside to be honest , car isnt going any where
- xr2irhys
Re: 37K Ford Fiesta
front ends nearly complete now just a few more nuts and bolts to do , and then be ready for spraying, my plan is to give the wings their first coat , fit them onto the car and then spray the front end all in one go , to save any scratches while fitting
this also means i can then seam seal them all on before next coat of paint and have the front end looking complete and finished
- xr2irhys
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
ah thats better, be better if they were black washers, once its bolted on, slap a load of seam sealer on the edges of the wings, especially where it meats the front top valance
Re: 37K Ford Fiesta
- xr2irhys
Re: 37K Ford Fiesta
good stuff, you got paint over your indicator lense
Re: 37K Ford Fiesta
jonyb4 :good stuff, you got paint over your indicator lense
Yep they cracked anyways so doesn't matter to much
- xr2irhys
