500 to Spend??
5 posts • Page 1 of 1
500 to Spend??
I have got around 500 to spend on a decent audio set up. At the moment i have a JVC headunit (the one with the interchangeable facia plates that came with the awful fire one) which im planning on keeping everything else i want to change. Im into RnB tracks and that sort of music.
I was thinking components and a sub but im pretty awful at audio, but do enjoy my music.
It will be originally for my fiesta but then moved into my ford puma which i should be getting in april. Any Advice people?
- mmorgan88
I'd go for some alpime type-r components up front, had for about £100. Amp these with an ok ish amp, £100. You can get an alpine type-r 500rms 12" sub for about £120 and another £150 should get you a decent amp to power it. The rest is for cabling. I'm not so good at amp, hence not giving names of any!
- lucasdemoley
I would spend about £100 on some good components, i would recommend these:
http://www.caraudiodirect.co.uk/rainbow ... -3855.html
I can't recommend this sub highly enough as i have it!! But i have a custom tuned box that fills the boot!! (Bargain at £90)
http://www.caraudiodirect.co.uk/audio-re10-p-2981.html
And to run the components:
http://www.caraudiodirect.co.uk/alpine- ... -2756.html
And to run the sub:
http://www.caraudiodirect.co.uk/alpine- ... -5518.html
Don't be afraid to mix and match things as different brands give better quality aspects of a system.
Also, steer clear of Sony/Kenwood in my opinion, spend a bit more and get quality that will last. I think the above is well in budget giving you enough change for a wiring kit and a good box to the sub, so as to get the best out of the amp and the sub.
And to run the sub:
- Wilson106
