£600 to make my 1.6s go like jolly flip
Postby rsfiesta on Sat Dec 23, 2000 2:34 am
Open to sugestions i have £600 max 2 tune my 1600 carbereted chariot.<br><br>I already have a airfilter<br> magnex exhaust<br><br>HELP ME PLEASE AS I NO NOTHING ABOUT TUNNING!!!!
rsfiesta
Postby Andrew Malcolm on Sat Dec 23, 2000 2:44 am
Your Car would sound the dogs nutts, and go like s*** of a shovel,<br><br> <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/smile.gif"><br><br>
Andrew Malcolm
Postby jon bda on Sat Dec 23, 2000 7:40 am
Make sure you do some other mods first,don't go straight for twin carbs.After you have the head ported+fitted with bigger valves,fitted a fast road cam and a vernier pulley,then think about the carbs,they ain't worth it on a standard motor.
jon bda
Postby muffking on Sat Dec 23, 2000 8:32 am
You can buy a full Turbo package for not much more than £600 if you look hard inough. But you'd have to fit it yourself.
muffking
Postby lauri on Sat Dec 23, 2000 11:16 am
nitrous
lauri
Postby Andrew Malcolm on Sat Dec 23, 2000 12:55 pm
Twin Carbs <IMG SRC="http://cgi.deep6.force9.co.uk/ubb/smilies/biggrin.gif"><br><br>
Andrew Malcolm
Postby rsfiesta on Sat Dec 23, 2000 1:49 pm
Specialised engines want £600 to supply and fit twin carbs is this a resonable price and would they make a noticable improvment...!
rsfiesta
Postby rsfiesta on Sun Dec 24, 2000 2:07 am
Would do that but i can no way afford the insurance!<br><br>will twin carbs use a lot more fuel?<br><br>Im getting my head sorted but im not shure wot cam 2 put in it. I dont want 1 that will slow me down off the mark!<br><br>please advise me.....cheeRS!
rsfiesta
Postby rsfiesta on Thu Jan 11, 2001 5:03 am
waitin for advice please!!!
rsfiesta
Postby nigel on Sun Jan 14, 2001 6:53 am
buy my van(see cars 4 sale)<br>only £600 with full turbo conversion<br><br>nigel
nigel
Postby Shug on Fri May 11, 2001 11:28 am
Get a kam kit (around £200 20bhp)
Chipped (£150 10bhp)
Get it R.R after your mods theyll get it set up the best way for the car (Around £80)
And if an extra 30bhp aint enough youre gona half to splash the cash for Nitrous or twin 40's
Shug
Postby Fiesta_S on Fri May 11, 2001 12:12 pm
is there anyway you guys can put together a list of what is good to do and where you can get them and approximate cost i.e best cam kits, where to get twin webbers pulleys etc i would rather get everything together first and put it all on in one go then should be able to notice a big difference obviusly bigger brakes etc would be required with the increase in power right? just at a rough guess with everything done what would the total BHP be after its RR?
Fiesta_S
Postby Shug on Fri May 11, 2001 12:20 pm
To Fiesta s
If you planned to do all these things in a oner to your car then get it R.R, youll die cause you wont be able to handle it.........
Shug
Postby Fiesta_S on Fri May 11, 2001 12:35 pm
fair enough im not saying there isnt going to be a difference i just asked as imple question asking what the BHP would be after it was RR with all the mods it probably wont happen and ill get the parts gradually to build up just wondered thats all by the way i aint that bad a driver 3 years no claims
Fiesta_S
Postby Robz_Fester on Sun May 13, 2001 12:33 am
You can't chip a carbed car.
Robz_Fester
Postby Project on Sun May 13, 2001 8:03 pm
Children!
Every1's got the right idea here. Basically, here's where methinks you want your wad to go:-
* New timing belt, oil (10w50) and brake fluid (DOT 5.1 seems to be recommended) - £10, £30 and £10
* EBC drilled & grooved discs and pads - £130
* Braided brake hoses - £50
* Sports shocks and springs if you have Ford kit on at the mo' - £300
With the remaining money, I would well recommend a set of performance leads, (I think the blue silicon Splitfire leads are about £30 and are all you will need) and plugs (£25 a set-ish) and then get the carb serviced and optimally tuned - no need for a RR session just yet.
The theory is that you will have far more confidence in the car if you can hammer into bends quickly (good suspension) and stop quickly (great brakes). Having a powerful car's no good if you don't have the confidence to handle it to it's full extent.
After that it's gonna be:-
* stage 3 head conversion (port & polish, fast road cam and pocket the pistons ('cos the valves will bash 'em otherwise), solid lifters) - £350-£450?
* 4-2-1 exhaust manifold (don't bother with S/S jobs as they tend to split along the bottom welds) - £200
* Vernier pulley timing gear - £60-ish?
* Rolling road tune - £????? but get the best you can afford
Sooooo... around £1145 plus the cost of the RR.
Al
Project
fiftyoneCL
fiftyoneCL
