7 Pin multi plug xr2i
3 posts • Page 1 of 1
Hi chaps,
Does anyone know what each wire on the 7 pin multi plug is used for (not the injector loom plug)
Im doing a conversion and this info would be amazing.
I know that the red is permanant live but im not sure what the others are for?
Car is an xr2i 8v cvh
Jim.
Jim.
- ginger9860
- Your car: Fiesta XR2I
Re: 7 Pin multi plug xr2i
The general rule is:
Red:permanent 12V
Black,(striped or not,depends on the application):switched 12V
Brown:Current return or earth
Green:Oil pressure
Tha above are true for a couple of Escorts and a Sierra,that I have worked on.I believe this is a general rule,but you should always measure with a multimeter as a precaution...
Red:permanent 12V
Green:Oil pressure
My Ford Escort ride
My Ford Escort ride
- georgiocat
Thanks for the info , i am going to try get my project running today.
I will take this on board thanks
- ginger9860
