ABS
5 posts • Page 1 of 1
ABS
Just a quick question, i've heard that braking can be improved by removing the ABS. At the mo I have 300mm front brakes and am getting focus rear disks, larger master cylinder and servo etc.
What are the pros and cons of doing this?
Dan
Dan
- dannyboy
You are miles better off without the FRST ABS as it's completely useless. I found that with the ABS the car would skip down the road when it kicked in and didn't realy help with steering as you have to correct this skipping Having removed it I've found that you can brake past the point where the ABS used to cut in without locking the wheels.
Regards,
Stephen
PS Anyone want to buy my old ABS modules?
Regards,
Stephen
- Quantum
