Actuator problems
4 posts • Page 1 of 1
Actuator problems
Hi all.
My T03 converted FRST runs a -31 actuator.. But it is just doing 6 - 7 psi at the moment.
Before the car is going on the RR to get a fine-tune i want to make sure my Actuator is working properly.
I've heard the -31 actuator either holds NO boost.. or it hold's 14psi+ boost..
is this correct ??
other question: Can i place my T02 Forge uprated actuator on my T03 without any problems ??
is this correct ??
- Jur
Don't think u can switch T2 & T3 actuators m8.
U can adjust the boost by unscrewing the nut on the rod then turning the rod then tightening the nut up i think.
- MIK3Y
Re: >
MIK3Y :Don't think u can switch T2 & T3 actuators m8.
Hi Mik3y
I know i can turn up the actuator ..
But i've heard the -31 actuator only works well above 1 bar. (14 psi) under this boost it will work improperly..
but then again.. i've just heard this..
why you think you can't swap the T2 and T3 actuator ? of the rod-length is the same .. it will work .. although the T2 has a bend in the rod.. but this is for the T2 to clear the turbine housing.. and should not have any effect on the T3
- Jur
What you have been told about the -31 is incorrect mate.
Its a linear rate spring and works fine from 8 - 15psi, or more with external assistance.
The T2 actuator wont fit because the band wont allow alignment with the wastegate.
Best Regards,
Stu
Best Regards,
Stu
- stu@mdevelopments
