Adjusting the actuator.
8 posts • Page 1 of 1
My boost gauge is only hitting 0.3BAR on max boost far too low for my liking, and i believe that a standard ECU will allow 8Psi (0.6BAR).
Is it just a case of adjusting the nut towards the actuator to increase my boost? Help much appreciated
- TomFRST
- GavStyli
- Your car: Fiesta Turbo
And how are you going to make sure there is enough fuel getting through after you turn up your boost ??
GET IT SET-UP PROPERLY
or you could being paying for a re-build very soon!
How many times do i have to say it!
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Fezzy Turbo :And how are you going to make sure there is enough fuel getting through after you turn up your boost ??
Damn good advice there
You will also need to fix whats wrong with it, the locknut didnt come undone, the shaft adjust and the locknut re-tighten all on its own did it?
Something has plainly broken
Amal valve is likely failed M8.
Best Regards,
Stu
- stu@mdevelopments
- stu@mdevelopments
