AFR meter tachofeed question
1 post • Page 1 of 1
Hello,
For all you techy's
I've bought a wideband AFR meter.
It can also monitor EGT, boost, throttle position and RPM.
For the last i need a 0-5V. input. The folder that came with the package said that i can get the feed from the tacho.
As i have to make up the loom, i think it will be easier if i can get the feed from the ECU or the pin connector on the bulkhead.
My question, does anybody know if there is a 0-5V. RPM signal?
And if so what number/colour?
BTW my FRST runs OFAC.
CheeRS,
Patrick J.
For all you techy's
CheeRS,
Patrick J.
- FordRSfanatic
