afr wide band
8 posts • Page 1 of 1
afr wide band
what do people think to these afr wide band stuff .is it useful on a zetec turbo conversion,[ERRR] im looking into getting 1
- MK4 Rick
- Your car: Mk5 Fiesta
Re: afr wide band
very useful if taken notice of as they can tell you when the engine is running dangerously lean or if it is running very rich.
they however are not replacements for a good setup session or mapping session but they are useful
- xrsi
- XR(ustyAtTheMo)SI
Re: afr wide band
i carnt find a link to the afr inovation site.can anyone help?
- MK4 Rick
- Smo
Re: afr wide band
im a bit stuck on which 1 to get,any advice and any ideas on which 1 i should get?
- MK4 Rick
Re: afr wide band
go to the guys site that makes a home made faultcode reader and you can build your own afr gauge
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
Re: afr wide band
whats involved in that process then.
- MK4 Rick
Re: afr wide band
ive got a autometer one, which at the moment is as much use as a broken lada to me!
The reason being is that i am not using a true wide band lambda sensor so it is getting confused to easily, that will all be sorted soon tho when i get the correct sensor for a forced induction car.
- xrsi
- XR(ustyAtTheMo)SI
