again another 1.6 8v conversion set of questions
6 posts • Page 1 of 1
right firstly have searched but couldnt find everything revevant to what i needed to know. so here goes.
i have a 1.4cvh si and wish to transplant to an xr2i 1.6 8v lump.
what is the total list of parts i need to do this?
*read in another post somebody needed tank, fuel pump, fuel lines etc but their car was not aa cvh fiesta, do i still need these components to make mine work?
* i smy gearbox going to be of any use to me for this conversion of do i need another one? if i do need another one what do you suggest, i swear i read somewhere that poeple used 1.8 diesel boxes in some conversions?
* do i need different engine mounts to fit this cvh which ultimately is identical to my existing engine bar being bigger at the bottom end.
* am i right im assuming that xr2is did not have a cat? if not how would i get around this problem. would my cvh manifold be of any use and my cat back system? if not i can send it off to longlife again to have it extended to meet a 2i manifold but how would i get around the m.o.t problem?
* so what exactly do i need then
*engine itself
*ecu
what else guys?
cheers for your help
*engine itself
*ecu
what else guys?
- 2309andy
Youre Gonaa need this andy.
- Fuel Pump
- Alternator
- Engine that comes with etc flywheel
fuel filter, oil flter, leads, spark plugs,coil pack etc, thermostat kit
injectors, cam belt etc
- tps air inlet sensor and coolant sensor
- xr2i inlet manifold with sensors
- Gearbox with clutch
-Ecu with wiring loom
- Dials
-Rad
-Exhaust manifold 4-2-1
- water tank aka header tank
- coolant pipes
- fan
andy im gonna have all this for you
my car is booked in for december time
so once myns done i will have all the above.
- Fuel Pump
- Alternator
- Dials
-Rad
- coolant pipes
- fan
- Xr_Dub
is the engine to a 1.4 si different to a standard 1.4 cvh?? because im thinking of doing the same thing to mine.
:: blade ::
:: blade ::
- :: blade ::
