Air Filter for a 1.6s
4 posts • Page 1 of 1
SHOULD be the same as for a Mk2 XR2. Air filter housing may be slightly different size. You should find the carb part number stamped into the side of the carb body - this is difficult to see when it's dirty and they usually always are, so clean it up with a little bit of petrol and an old toothbrush.<br><br>Regards<br>Craig
- Craig
Hi all,<br><br>This is my first post so please be gentle just wondering if anyone knows if you can get a k&n or something of equal standard to fit and if so where can you get them from when i rang k&n they asked for the number stamped into the air filter but i couldnt find it do you know what they mean any help would be appreciated.
- Fiesta_S
Take the standard air filter out, then just shove a Piper-Cross sock over then intake (about £15 for a pair) - used on the ends of carbs, and much cheaper than a pain in the a*** K&N...
- Project
- fiftyoneCL
