Air Filter? TO MANY TO CHOOSE FROM!!!
Postby snOOpy86 on Fri Nov 08, 2002 10:34 pm
hey, just wonderin [ERRR] the best/preferd air filter is? :Q
*bumshakes sweet and innocent ickle baby*
snOOpy86
Postby TomFiesta on Sun Nov 17, 2002 11:07 am
Depends what car you got!!?? :rolleyes:
TomFiesta
Postby NAB on Sun Nov 17, 2002 2:57 pm
Ive got a Green cotton on my FRST.....not sayin its the best or the worst, i like it.
NAB
Postby MattGomFRST on Wed Nov 20, 2002 5:29 pm
Alrite mate,
I got a piper x on my FRST, it sounds a bit s**t with standard exhaust, but once i put my 4in scorpion full system zorst on it sounds lurvly. :D :D
One of the best ones to get would be the piper x viper, because it comes in carbon fibre, and has hot and cold pipes etc, but unfortunately, it aint available for the FRST, hopefully they will make one soon.
MattGomFRST
Postby moulder on Wed Nov 20, 2002 8:06 pm
A lot of people say that induction kits are bad as they let loads of hot air in and generally do not filter well. Y not keep the standard air box and drill some holes in it and then use a perfomance panel filter like k and N or piper x. But if u just want noise then an induction kit it is but to be honest I doubt u will see a big bhp gain as you need to get the fuelling to match etc. :D
moulder
Postby davy on Thu Nov 21, 2002 4:43 am
moulder :A lot of people say that induction kits are bad as they let loads of hot air in and generally do not filter well. Y not keep the standard air box and drill some holes in it and then use a perfomance panel filter like k and N or piper x. But if u just want noise then an induction kit it is but to be honest I doubt u will see a big bhp gain as you need to get the fuelling to match etc. :D
True they may allow hot air in though only at a stand still. this is not going to have much effect on performance is it? the standard air box is also going to letting hot air in when stationary. Once you have some airflow you'll be laughing.
Aftermarket air filters will either meet or exceed industry standards for filtration. so any horror stories you here are probably from incorrectly fitted or poorly maintained filters.
You should get air/fuel correct just by disconnecting the battery for around half an hour after fitting so that the ecu can reset and reg the new settings ( assuming the car is injection and not carb )
Performance increases will vary from application and some may only give you only 1/2bhp, though all should give a positive effect. why bother manufacturing a product which is less effective than what is already available as standard??
davy
davy
Postby DorsetZS on Thu Nov 21, 2002 2:19 pm
never knew that about the battery good advice for the future !!
DorsetZS
Postby davy on Thu Nov 21, 2002 10:08 pm
resetting the ecu will only compensate for small amounts of change in air / fuel mixture such as fitting a air filter. anything more and youd need to start chipping the ecu.
davy
davy
