Air Filter?
Air Filter?
Postby rach652 on Wed Jun 20, 2007 9:08 pm
Would a universal air filter be able to be fitted to a fiesta mk3 1994 model?
& would it make much of a difference on this sort of car?
rach652
Postby XR2i-Fiesta- on Wed Jun 20, 2007 9:18 pm
wont make any difference aprt from being a bit noiser, also depends if u have a bold on top airbox then a uni filter wont fit :bonkers:
XR2i-Fiesta-
Postby gumpy on Wed Jun 20, 2007 9:19 pm
[ERRR] engine u got??
gumpy
Location: barry, south wales. drives: fiesta xr2i replica
Postby rach652 on Wed Jun 20, 2007 9:23 pm
only 1.1, just got a cheap one off ebay. Bit of a bimbo when it comes to these sort of things!
rach652
Postby gumpy on Wed Jun 20, 2007 9:26 pm
u need a k&n bolt on filter there is a thread in guides called obtaining and fitting a bolt on filter , hope this helps :)
gumpy
Postby gumpy on Wed Jun 20, 2007 9:28 pm
double post.
gumpy
triple post :o
gumpy
Postby rach652 on Wed Jun 20, 2007 9:29 pm
thanks! will have a look
rach652
Postby jos310581 on Thu Jun 21, 2007 3:21 pm
Why bother spending fifty quid on something that will make a noise, just take your airbox off and drill it all the way round, it will give you same affect of a K&N, just remember your air filter will need changing more. :Q
jos310581
Postby rach652 on Thu Jun 21, 2007 3:23 pm
Sounds like a better option!! :D
rach652
Postby jos310581 on Thu Jun 21, 2007 3:26 pm
If you want more help in drilling the box just check out my first post, it explains all, well best I can :rolleyes:
Have fun :)
jos310581
Postby rach652 on Thu Jun 21, 2007 3:34 pm
Thanks, will take a look at that :)
rach652
Postby j7aoc on Thu Jun 21, 2007 6:03 pm
Your car must be a 1.1i as it's a 1994 and K&N don't do a bolt on fliter or induction kit they only do the element E-9092 £34.10 :wink:
j7aoc
Postby rach652 on Fri Jun 22, 2007 8:15 am
Ok cool, so would the drilling work on my filter? :idea:
rach652
Postby j7aoc on Fri Jun 22, 2007 8:20 am
rach652 :Ok cool, so would the drilling work on my filter? :idea:
Yes i think you are ment to do just the top part. Take a picture of you engine bay and post it up? That way i can see if you could get and induction kit on there I can find out some massurement's of kit's
j7aoc
Postby rach652 on Fri Jun 22, 2007 8:43 am
Cheers, just off to work but will post that up later this afternoon!
rach652
Postby rach652 on Fri Jun 22, 2007 4:43 pm
rach652
Postby FezV6 on Fri Jun 22, 2007 5:26 pm
the only parts of that style airbox that you can drill are the outer edges, so it only allows air in outside the filter.
FezV6
Postby j7aoc on Fri Jun 22, 2007 5:53 pm
They only thing you would get to fit would be a bolt on type and you would have to know your stuff to find one to fit
j7aoc
Postby rach652 on Fri Jun 22, 2007 6:03 pm
Hmm, ok. Is it more hassle than its worth!?
rach652
Postby j7aoc on Fri Jun 22, 2007 6:12 pm
rach652 :Hmm, ok. Is it more hassle than its worth!?
You could get one to fit but wouldn't be easy :cry:
j7aoc
Postby rach652 on Fri Jun 22, 2007 6:13 pm
Yeah ppl have said it wud be quite akward to fit
rach652
Postby j7aoc on Fri Jun 22, 2007 6:24 pm
The only way do get one to fit is to remove the old airbox and measure the hole then the depth of your old box so the new filter won't hit the under side of the bonnet
j7aoc
Postby rach652 on Fri Jun 22, 2007 6:26 pm
Yeah, may be worth a try doing that
rach652
Postby j7aoc on Fri Jun 22, 2007 6:41 pm
rach652 :Yeah, may be worth a try doing that
It would look loads better as that standard one looks pants if you find out the measurements i will do my best to see what one will fit i have some one's that i was going to bin but i can wait then maesure them will give you some ideas
j7aoc
Postby j7aoc on Fri Jun 22, 2007 6:48 pm
j7aoc
Postby gumpy on Fri Jun 22, 2007 7:07 pm
mine bolted straight on or you can do what i done before and cut the casing on the airbox up so all thats left is the top and bottom of the airbox and the filter is exposed :D
gumpy
Postby gumpy on Fri Jun 22, 2007 7:18 pm
heres my k&n bolt on my suzuki swift.
heres my green cotton bolt on , on my 1.1
and this is the old cut up air box
hope this helps :D
gumpy
Postby rach652 on Fri Jun 22, 2007 7:26 pm
That could work :D
rach652
Postby j7aoc on Fri Jun 22, 2007 7:43 pm
Look what i have
:Q might be to big
j7aoc
Postby rach652 on Fri Jun 22, 2007 7:46 pm
Hmm..thinking wud i actually be able to close the bonnet :idea: lol
rach652
Postby j7aoc on Fri Jun 22, 2007 7:50 pm
rach652 :Hmm..thinking wud i actually be able to close the bonnet :idea: lol
Stick a brick there first then slam the bonnet then remove the brick replace with air filter job done You then have a bonnet bulge :lol: :lol: :lol:
j7aoc
Postby rach652 on Fri Jun 22, 2007 7:52 pm
lol :D
rach652
Postby j7aoc on Fri Jun 22, 2007 7:55 pm
What car is that off :-?
j7aoc
Postby fiend on Fri Jun 22, 2007 8:13 pm
Where did you get the filter for the oil filler cap from?
fiend
