Air Filter?
44 posts • Page 1 of 2 • 1, 2
Air Filter?
Would a universal air filter be able to be fitted to a fiesta mk3 1994 model?
& would it make much of a difference on this sort of car?
- rach652
wont make any difference aprt from being a bit noiser, also depends if u have a bold on top airbox then a uni filter wont fit
- XR2i-Fiesta-
Why bother spending fifty quid on something that will make a noise, just take your airbox off and drill it all the way round, it will give you same affect of a K&N, just remember your air filter will need changing more.
- jos310581
Your car must be a 1.1i as it's a 1994 and K&N don't do a bolt on fliter or induction kit they only do the element E-9092 £34.10
- j7aoc
Yes i think you are ment to do just the top part. Take a picture of you engine bay and post it up? That way i can see if you could get and induction kit on there I can find out some massurement's of kit'srach652 :Ok cool, so would the drilling work on my filter?
- j7aoc
They only thing you would get to fit would be a bolt on type and you would have to know your stuff to find one to fit
- j7aoc
- j7aoc
The only way do get one to fit is to remove the old airbox and measure the hole then the depth of your old box so the new filter won't hit the under side of the bonnet
- j7aoc
It would look loads better as that standard one looks pants if you find out the measurements i will do my best to see what one will fit i have some one's that i was going to bin but i can wait then maesure them will give you some ideasrach652 :Yeah, may be worth a try doing that
- j7aoc
- j7aoc
- j7aoc
Stick a brick there first then slam the bonnet then remove the brick replace with air filter job done You then have a bonnet bulgerach652 :Hmm..thinking wud i actually be able to close the bonnet lol
- j7aoc
- j7aoc
