Air filters for.....
19 posts • Page 1 of 1
- DunnysMK3
try http://www.kandn.com they do a direct replacement filter, theres also a bolt on filter i think. try doing a search, its been fairly commonly asked about on here.
- hb69
- Your car: Fiesta 1.1 LX
To be honest mate it just isn't worth doing. All you may get is a bit more induction noise and you can get that by taking a 10mm drill bit to your existing air box but due to its position it will just draw in warm engine air.
I's spend the cash on a back box to improve the looks and give it a bit more growl
the 1.1 and 1.3 hcs engines are only distinguishable from the outsied by the number embossed on the block near the alternator 1.3 says 1.3 and 1.1 says 1.0-1.1
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
try fleabay mate, i got mine off a xr3 carb model just re-drilled the base plate and on it went ,also attemted to get a bit more cold air to it by fitting some greenfilters air ducting prob does f**k all TBH.
projectMK3
projectMK3
- PMK3
the k&n ones do roar sweetly when you go flat out but i'm still wondering what to do when summer comes cos like other have said, it'll just suck in hot air.
Might make a box and tube for it. Hang on, Ford's air boxes were like that anyway *sigh*
Project_mk3. I had something like that in mind, maybe some sort fat v-shape bit on the end would make the filter suck through the pipe? Just throwing ideas in the air at the mo
- Tweek
- Your car: VW Golf GTD
yeah thats a good idea tweek.you can get universal brake ducts in the shape you mention from demon thieves so could be done "fairly" easy,but im not too bothered.BTW its sit lovely where ive got it,below the lip of the bonnet nestled in between the side of the rad and front panel.
cheers porjectMK3
cheers porjectMK3
- PMK3
yes mate,no probs.Isnt too difficult if your confident with a drill .IF you get too stuck il wip mine off and show you some pics
projectMK3
projectMK3
- PMK3
I've found part of the air duct off an Audi Coupe or something, it has a round hole one end, turns 90 degrees and then opens up into a fat oval. No idea what the size is but its rubber, flexible and a useful shape.
I shall look into this more once i've got the other 150 problems fixed
- Tweek
yeah i know what ya mean mate,fix one problem and another two appear .keep this thread posted with pics if you do fit a duct for the filter.might try it if its fairly effective,and cheap
projectMK3
projectMK3
- PMK3
k&n bolt on air filter
part number = '56-9042'
got mine from carcraft,but i spose if u get it from ebay you could ask the seller the part number.
(make sure you ask for bolt on if you use a shop,or they will order a k&n ring that goes in your original airbox like they did with me haha)
- fiestyRS
i got a k&n from demon tweeks,told the exactly what car and spec it was for and they still sold me 57i induction kit ,fudgekin useless c**ts.so make sure they know you want people dont understand "bolt on" it seems
cheers projectMK3
cheers projectMK3
- PMK3
fiestyRS :k&n bolt on air filter
Thanks mate, have carcraft got a website??
- DunnysMK3
