Air lock
7 posts • Page 1 of 1
The boyfriend put on a new radiator not so long ago, and now i'm losing loads of water and part of the radiator always remains cold, this inidicates to me that I have an air lock, how the hell do I fix this?!
- Kat
Kat hun - check the breather pipes that are attached to your rad, if they're all ok, then take the header cap off and turn the bleed valve on the rad so that all the water pours out, wait about 5mins then close the bleed valve, fill your header tank back up as see if that sorts it out.
Make sure you've not had the car running for a while as you WILL burn yourself.
- Paul RS1800
- Blue Thunder
LOL! on the lines of burning ur self !...
i opend my bonnet today, but couldnt get the bonnet stay up to the hole, cos i was burning my bloody hand took ages to do..
i'd just taken th car a a raz b4 as well so i supose that added to the heat
also the stay is chrome....
- Phil Si
Car: 2000 BMW 330 Ci
Phil mate I think I've forgotten the amount of times I've stuffed my hands under the bonnet to check things and ended up burning myself
- Paul RS1800
- Blue Thunder
