amp earth
amp earth
Postby millsy2102 on Fri Oct 26, 2007 5:41 pm
hi everyone, im new here and looking for some advice.
basically i am trying to fit a sub in my gfs mk4 fiesta, but i cant seem to find a decent earth. can anyone give an example of where they have theirs??
also i had the sub working for a bit, when it was working it would only work when the radio was playing, not the cd. any ideas??
millsy2102
Re: amp earth
Postby gumpy on Sat Oct 27, 2007 1:57 pm
i drilled a hole in the boot floor ( carefull u dont drill through the fuel tank) took the around the hole to bare metal and bolted the earth to there. hope this helps :D
gumpy
Location: barry, south wales. drives: fiesta xr2i replica
Re: amp earth
Postby dontpannic on Sun Oct 28, 2007 12:25 am
millsy2102 :also i had the sub working for a bit, when it was working it would only work when the radio was playing, not the cd. any ideas??
With some Headunits the auto antenna outputs are only active when the radio is on, so you might be better off wiring the remote wire into an ignition switched live.
