amp not working??
amp not working??
Postby ryan_u89 on Sat Apr 07, 2007 12:14 am
Hi
The power light on my amp is not coming on and i dont know why
i checked the power cable, fuse etc, and it is all wired up properly. also the earth but im not sure if it is earthed properly. what do i need to do to make sure the amp is earthed properly? also are there any ways to test my amp to see if it works?
Ryan
ryan_u89
Postby Jonezy on Sat Apr 07, 2007 1:13 am
have you checked the fuse at amp and at the battery? check these then check for breaks in the remote wire (the blue one).
Jonezy
Postby ryan_u89 on Sat Apr 07, 2007 9:38 am
yeh i checked them and they seem ok, im going to try another power cable today tho. does the remote lead have anything do with power though? because the amp light is not coming on so i just thought it would be either earth or power?
ryan_u89
Postby Oranoco on Sat Apr 07, 2007 9:56 am
Could be the remote as it's this lead that tells the amp to turno on.
Oranoco
Postby ryan_u89 on Sat Apr 07, 2007 6:07 pm
thanks for your help but i sorted it. i took apart the in line fuse and there was loads of black s**t and the actual fuse had fallen apart inside!
ryan_u89
