Amp's on standard head unit?
Postby dontpannic on Tue Jul 10, 2007 6:57 pm
Hiya. I know it probably isn't possible but worth a shot anyway!
Is it possible to wire up an amp (JBL GTO 19.5) to a ford stock head unit? Getting a MK5 and wanted to keep the standard headunit but need my amps. If it's not possible I don't care, I'll just go and get a better headunit, but just wondered if it was possible...?
Nick
Postby fiend on Tue Jul 10, 2007 11:53 pm
I don't think the standard headunits in the MK5's have RCA outs.
I remember hearing about some device you can get to run a sub off your speaker wire.. or something weird/dodgy like that.
..a new head unit will always be better. :lol:
fiend
Postby dontpannic on Wed Jul 11, 2007 8:19 am
fiend :I don't think the standard headunits in the MK5's have RCA outs.
As I thought. I would have upgraded anyway just thought as an interim measure... I'll save for a better HU.
Cheers.
Nick
Postby James2k on Wed Jul 11, 2007 5:34 pm
I was about to ask the same thing but i have a Vectra C and cant be arsed buying a new head unit till i get the funds. and plus i have the seperate display and steering wheel controls.. Wanna run 2 subs but i need a way of converting the normal output signal into a sub mono? :-?
Please Bassboy to the rescue....
James2k
Postby bassboy on Wed Jul 11, 2007 10:57 pm
Yep it can be done without much hassle ;)
what you need are speaker to RCA's converters which basically splice into the rear speaker wires (or front its up to you) and these then have phono plugs on them...
these are the ones to go for
http://caraudiosecurity.com/shop/produc ... /3794.html
if you need some drop me a PM and ill sort something out for ya ;)
they also have an earthing lead on them which tries its best to eliminate ground noise when using them...and in all honesty...these are the best ones to go for when doing everything on a budget...MUCH MUCH better than the crap Autoleads ones
The other option you have is the Audiocontrol LC6 for example...but its £300 or so but is an amazing bit of kit!
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby dontpannic on Thu Jul 12, 2007 8:09 am
Ah ha, thats pretty good. I just am getting a cassette player in the new car but am upgrading that pretty soon - I was looking at the OEM units as they fit the dash nicely.
I'll PM ya when I decide what to do!
Cheers matey!
Nick
Postby JayC on Thu Jul 12, 2007 12:48 pm
dont run your speaker outputs strait into the line youll blow it.
if your amps have high level inputs, you can wire from the headunit strait into these 2 channels.
Project62 ~ my baby
2Liter Fiesta Si Thread:)
JayC
Postby JayC on Thu Jul 12, 2007 12:51 pm
sorry just seen bassboys post ill go away :lol:
Project62 ~ my baby
JayC
Postby James2k on Thu Jul 12, 2007 4:21 pm
Will that Directed Speaker to RCA lead be ok For just subs?
And also were can i get a remote lead for turning the amps on?
James2k
Postby dontpannic on Thu Jul 12, 2007 8:25 pm
JAmes2k :Will that Directed Speaker to RCA lead be ok For just subs?
I used an ignition switched feed from the 4 copper panel (2nd one I think).
Postby James2k on Thu Jul 12, 2007 9:23 pm
I've gotta 02 Vectra now so might have to do a bit of tinkering.....
Bassboy???
James2k
Postby dontpannic on Fri Jul 13, 2007 8:06 am
JAmes2k :I've gotta 02 Vectra now so might have to do a bit of tinkering.....
Bassboy???
That will be OK for subs, as long as your amp can distinguish between bass frequencies.
It sounds really insane, but I prefer the look of standard headunits in the car, plus with the 6000 RDS unit I can do everything I need to with it, especially with that add on.
Nick
Postby bassboy on Fri Jul 13, 2007 1:03 pm
if the car has an ariel on the roof then use the remote feed off that to switch the amps on....failing that use an ignition live...
but yes the rca's can then be used for any amp whatsoever
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby dontpannic on Fri Jul 13, 2007 2:01 pm
bassboy :if the car has an ariel on the roof then use the remote feed off that to switch the amps on....failing that use an ignition live...
bassboy
Did you get my PM fella?
Nick
