amps
2 posts • Page 1 of 1
amps
hi can someone plz help me, im having problems,
not so long ago i wired up an electrics pack loom in my car, just after that my music started to go, i thort it was my head unit but wasnt, just had to put new electrics pack speaker wires into my head unit, my my subs arnt working?
when i was driving before i swapped the over it worked now and again, 1st time the sound cut out and only bass, then it all worked fine, then driving home from work one day, just cut out, any ideas?
could be to do with the new electrics pack? or dodgy wiring as it was abit s**t setup in the boot, not sure if its right, there is def power as the light is on both amps, ive tested it with a bulb too, working fine, then tryed to hold a normal speaker over and touch the wires, but no sound, so power is getting there but nothing from the other side of the amps
can anyone tell me the best way to wire up 2 subs and 2 amps, so its 1 sub to 1 amp
- frstlad
- Your car: fiestas
