any way to fix this??
Postby eqraz on Wed Jan 23, 2002 7:01 pm
hi, i have a 1990 g reg xr2i and the previous owner had put a strip of thin blue tape down the side of the car, like a speed stripe bout 3" above the standard rubbing stripe, i decided to remove it.
on some bits not all beneath the stripe there is a kinda line where 2 layers of paintwork meet well where there is a line where either the previous owner has SCORED along the paintwork to make the line straight or somethin else
above where the line used to be on some bits the paint seems a layer higher than the stuff below the line, hmm im confused its only small and noticable when you look up close but is there any way of making it un noticable? ie. blending in the 2 layers of paint?
any ideas welcome
eqraz
Postby KEVFRST on Wed Jan 23, 2002 8:26 pm
Maybe it was hiding a $hite paintjob which was not properly blown into the original paint!!! Try using loads of T cut, wont cure it properly but may make it look a tiny bit better. :wink:
KEVFRST
Postby cubby240 on Wed Jan 23, 2002 11:05 pm
The only way is to rub it down and give it a fresh coat of paint :sad: :sad:
Cubby
cubby240
Postby eqraz on Thu Jan 24, 2002 12:03 am
yea thats what i suspect too my mate says t-cut it lots of times and it will blend in
what should i use?
original t-cut or metallic t-cut?
btw my paint is mercury grey
eqraz
Postby wiacek on Thu Jan 24, 2002 1:59 am
maybe sum of the panels have been resprayed due to damage. ive heard its a common place to find dodgy paint work :rolleyes:
wiacek
Postby Danny 2i on Thu Jan 24, 2002 1:50 pm
Could you try rubbing compound? It might be a bit coarse though? Could be worth a shot... :???:
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby eqraz on Thu Jan 24, 2002 11:36 pm
had a m8 look at it, he says its a dodgy paint job, ive t-cutted it a few times and it looks loads better but still not perfect, whats rubbing compound?
eqraz
Postby Danny 2i on Fri Jan 25, 2002 1:07 am
Its like a paste (you can buy it from Halfords) which has little bits in (like exfoliant facewashes! :lol: ) that rub up the paintwork.
I think its used for doing stuff like this but dont take my word on it...i never tried it myself!!! I would imagine it would do the job though...
Danny 2i
The White 2i Guy!
The White 2i Guy!
Your car: N/A
Postby eqraz on Fri Jan 25, 2002 1:14 am
ok m8 cheers
is there any stuff that actually blends 2 different layers of paint together?
or am i gonna be t-cutting it till im 83?
eqraz
Postby sleeky2001 on Fri Jan 25, 2002 5:14 pm
Rubbing compound is good for blending paint, but BE CAREFULL! Its tough stuff and if the layer of paints thin it could remove too much paint, I know, it happened to me! I had spent ages fibreglassing and filling my esiting ariel hole, and after doin a luvly spray job on it, set to blending the paint in. After a harsh session with the rubbing compound it looked a lot better, but had also taken some of the paint off leaving bare metal :sad: So I had to have the top 1/2 of the wing repsrayed!
sleeky2001
Postby The Gilly on Fri Feb 08, 2002 6:12 pm
Oh sleeky where's your toe eye cover on your XR2? :eek: :eek: :eek: :eek:
The Gilly
