anyone done the twin anti rollbar trick on the rear?
72 posts • Page 2 of 3 • 1, 2, 3
Re:
pornstar! ::-? Gawd knows, someone on here who hasnt seen a girls fanny will proabably correct me but i thought the first FRST's came without one?
Meh! It's done and it works!
neil u crease me up man
- Xr_Dub
Re: anyone done the twin anti rollbar trick on the rear?
from my experience with the bolts on the rear only yesterday.. i would say you would need longer bolts about 10mm longer.. however if the bolt is threaded all along the length it will bite into the eyelet on the bottom of the strut.
- JayC
i done this the another to my frst ill post a pic
- SEG1
Si's have rear ARB's.. just thought ide add that.
- JayC
RS_seg :i done this the another to my frst ill post a pic
Get on with it then!
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
- SEG1
- Ollybee
Wow this looks a bit fancy.............. anybody else got some more pics?
Tiller
Tiller
- TIL13R
cool
this looks intresting, might have to source me another anti roll bar
catch you later
catch you later
- rsonblackwheels
I want to do this too.
- XRMike
Does anybody know what issue this was in?
Tiller
Tiller
- TIL13R
Re:
pornstar! :Yep, but for a normal road car with average suspension dont expect to set the world on fire.
i run Gaz Gold coilover, full set of Powerflex bushes (everything), new front and rear roll bars, lower arms and a proper set-up.....although i have messed with my settings since.
It stiffens the rear end up very well on my motor.
what setting you running now? got to take mine for geo set up before 24th at donno, was going to take the mag along and get them to set it to that! now you have changed it to what? and what diff has it made mate?
- gregs
i wanna do this my beam is out and i have 2 anti roll bars does anyone have better pics as i cant see how it goes
- rs-tom
I'll be doing it either Today or tomorrow evening. You need longer shocker bolts (I just looked through a tin of old assorted bolts), and longer inner bolts (these are very easy to come by).I'll get some pictures of how I do it.
- XRMike
XRMike :I'll be doing it either Today or tomorrow evening. You need longer shocker bolts (I just looked through a tin of old assorted bolts), and longer inner bolts (these are very easy to come by).I'll get some pictures of how I do it.
Cheers Mike
- TIL13R
can it be done on the car or does it all have to come off?
step by step guide would be ace
- jason-jm
awwww this sounds awsome..
please can someone do a step by step guide plzzzzzzzzzzzzzzzzzzzzzzzzzzjust can't make out from the pic...
XR2I 16V
- magic_john
There's a guide in the june or july 2007 issue of fastford
I have parts for sale!!!!.....Nice parts too!!!
http://www.fiestaturbo.com/forums/lots-of-parts-for-sale-vt185591/
- MattPym
No links i'm afraid! I'll get a scan of it later if you want
- MattPym
Will get a scan after later on after college then
- MattPym
Here's the article, Not exactly what i would call in depth, But TBH step 15 pretty much tells you everything you need to know!
- MattPym
No problem lad!
- MattPym
thought id boost this back up for some people who havent seen it. only found it as someone was tlkaing about it other day.
also go a question do you need longer bolts to refit with the second arb?
- Minstral
- Your car: *
yep i used longer bolts on mine.
- SEG1
do they have to be special ones? or can you just get them from b&q?
- Minstral
- Your car: *
Mistral :do they have to be special ones? or can you just get them from b&q?
It was me that was talking about it
From what i have heard you can use any bolts, just need to be longer than the standard ones as has been said
There is a guide here too, that i copied over from FSi for someone:
http://www.fiestaturbo.com/forums/looking-for-rear-lower-strut-vt172867/?hilit=%20anti
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
ill definately do that at some point. any 1 no the size of the 2 bolts that go in either side as standard?
- Minstral
- Your car: *
My twin rear roll bar is slightly different to the way above, my second one sits the same way as the other one, just lower.
- Ratspeed
Like this Ratspeed?
I would do it this way, wouldn't have thought it would make a difference which way round they are
Or does it?
Or does it?
- M1K3Y_B
mine is the same as above aswell. i have to say it is a well worth mod,
- White2i
mine looks similar to that mikey, just not as rusty!
- Ratspeed
Ratspeed :mine looks similar to that mikey, just not as rusty!
Its not a pic from my car
- M1K3Y_B
