anyone got any 2.1 zetec turbo megasquirt basemaps
4 posts • Page 1 of 1
anyone got any 2.1 zetec turbo megasquirt basemaps?
i have just built mine useing megasquirt and its running lumpy like its fireing on 3 and also pinking.
im running bosch 803 injectors if that helps
any of you guys go any ?
thanks
thanks
- jjcool
Download some megaquirt base maps for the zetec turbo:
http://www.extraefi.co.uk/downloads.htm
You should take it to a proper tunner to map it on the rollers and then on the road.
These maps were done by non-professionals, so don't trust them. They are only a starting point.
- BUTRE
Is mega-squirt hard to install?? i know it says all the wires are labeled etc but is it hard to wire up and to connect everything together?
And are you limited to 19psi or do they go over this???
- Brammer
- Your car: Sierra Cosworth
