Anyone Got PI Shocks + Spring
10 posts • Page 1 of 1
I've had to sell my Coilovers as they didnt fit my MK3.5 so looking to order another kit today but only ones i can find for my 3.5 is a Spax VSX kit (Wanted the PSX one but they only do them for MK3) or a PI Kit i've never heard of anyone using the PI kit so does anyone on here use it and any opinions on it?
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
Didnt know i could fit mk3 hubs to be fair, as the car has PAS and i thought the lower arms were different, correct me if i'm wrong.
- mrorange2
I had pi full kit on my 2i and it was new and cost me £260 and was one of the best thing a did on my 2i it never put a foot wrong
But wouldn't you have to change the lower arms and even if you put second hand hub's on you you would be mad not to do the wheel bearings Lower arms £40 each hub's new £127 each bearing £35 eachOranoco :Cheap and cheerful.
Why didn't you just fit earlier Mk3 hubs and then use your coilovers?
- j7aoc
I do both the Spax & PI, there both very very similar. Spax seem to be the more popular choice amongst ford fans though. If your wanting adjustablity then go for the Spax, id recommend the PSX kit.
- KEVFRST
KEVFRST :I do both the Spax & PI, there both very very similar. Spax seem to be the more popular choice amongst ford fans though. If your wanting adjustablity then go for the Spax, id recommend the PSX kit.
I wanted the PSX kit but they dont do them for the MK3.5
- mrorange2
j7aoc :But wouldn't you have to change the lower arms and even if you put second hand hub's on you you would be mad not to do the wheel bearings Lower arms £40 each hub's new £127 each bearing £35 eachOranoco :Cheap and cheerful.
Yes I'm sure you would need to swap some other bits over as well but it would mean the coilovers could be used. I'm not a fan of coilovers but it seems a huge leap backwards to go for SPAX or Pi
KEVFRST :In that case, you need Bilstein dampers with H&R Springs on.
Whys that then i know bilstein are good but why with H&R springs?
- mrorange2
