Anyone used Audi 1.8T pistons in a 1800 zetec turbo? : Tuning / Handling / Braking | Fiesta Forums
Postby freak power on Mon Nov 30, 2009 12:13 am
I'm sure i read it somewhere before as the Audi Pistons are 81mm with a 20mm pin
freak power
Re: Anyone used Audi 1.8T pistons in a 1800 zetec turbo?
Postby Ruishy1 on Mon Nov 30, 2009 8:58 am
someone in a ford magazine used them, it was a red xr2i IIRC.
They can be used and are stronger than the vaux pistons
Ruishy1
Postby crazycage on Mon Nov 30, 2009 10:12 pm
Ruishy1 :someone in a ford magazine used them, it was a red xr2i IIRC.
i dint see the point really when its the rods and bolts that are the main week link and rod and piston packages are not that expensive these days
crazycage
Postby dangerousdave on Mon Nov 30, 2009 10:39 pm
and why go build 1.8 when 2l has so much more power for a similar cost! :) :P
dangerousdave
Postby Ruishy1 on Mon Nov 30, 2009 11:18 pm
crazycage :
some people have a tight budget to work on, and for all the price of forged pistons and i/h beam rods has come down, its still and expensive for some people when they are not chasing huge numbers.
dave, there are certain race classes where there are rulles and regs on capacity, he might be aiming for a certain one, just a thought :)
Ruishy1
Postby freak power on Tue Dec 01, 2009 8:36 pm
good as i will have some for sale soon so i just needed to confirm
freak power
Postby crazycage on Wed Dec 02, 2009 7:26 pm
Ruishy1 :
crazycage :
i agree that if you are not after big bhp then you dont want to spend out on rods and pistons but if that was the case then a de-comp plate and a standard engine is the way to go and you can run upto 250hp with no probs .
crazycage
Postby Ruishy1 on Thu Dec 03, 2009 1:23 pm
i would never use a decomp, your opening the possibilty of HG failure times two due to increased sealing surfaces.
i ould always use pistons where possible ather than the bodge way :)
Ruishy1
Postby dangerousdave on Thu Dec 03, 2009 1:27 pm
Ruishy1 :i would never use a decomp, your opening the possibilty of HG failure times two due to increased sealing surfaces.
some people like myself cant afford pistons and rods and those that can will buy 2l ones with forged rods to get the cr required!
also look at how well heemans decomp plated 1.8 zetec runs......
dangerousdave
Postby dangerousdave on Thu Dec 03, 2009 1:28 pm
dangerousdave :
some people like myself cant afford pistons and rods and those that can will buy 2l or 2.1 ones with forged rods to get the cr required!
dangerousdave
Postby freak power on Thu Dec 03, 2009 6:31 pm
Well i will be selling some of these 1.8T 20v Turbo pistons soon they are forged and can be made to fit the Zetec rods
I only want £150 for all 4 anyway to if someone offered me these or a £50 decompression plate i know what i would get
freak power
Postby Ruishy1 on Fri Dec 04, 2009 9:09 am
dangerousdave :
rather than a decomp, i would get the combustion chambers machined to lower the cr, or a thick copper HG rather than a decomp.
Thats just me however :)
Ruishy1
Postby freak power on Fri Dec 04, 2009 9:01 pm
Never used a copper head gasket?
I would rather go down the forged pistons and MLS head gasket
freak power
Postby freak power on Sun Dec 06, 2009 3:09 pm
WIth a little machine work to the Zetec rods they do fit
freak power
Postby Ruishy1 on Sun Dec 06, 2009 4:30 pm
are they the correct height ?
Ruishy1
Postby freak power on Sun Dec 06, 2009 4:52 pm
They are
freak power
Postby Ruishy1 on Sun Dec 06, 2009 6:16 pm
what machining was need to fit them ?
Ruishy1
Postby freak power on Sun Dec 06, 2009 7:04 pm
The Zetec pin is bigger than the S3 so the zetec rod needs to be machine to to fit a S3 small end bush.
With this modification it makes the rods fully floated pins so you can remove and refit the piston without heat or a press
freak power
Postby Ruishy1 on Sun Dec 06, 2009 7:20 pm
ah, an easy fit then :)
Ruishy1
Postby freak power on Sun Dec 06, 2009 7:35 pm
Most machine shops will charge you from £50 to £100 depending on where you and there experience.
freak power
Postby daz131 on Sun Dec 20, 2009 7:10 pm
are these still for sale??
daz131
Postby freak power on Mon Dec 21, 2009 6:55 pm
You have PM
freak power
Postby XRMike on Sat Mar 20, 2010 9:37 pm
Freak Power im always inspired by your work and 'thinking outside the box'. This seems like a great way of safley turboing a Zetec without the possible reliability issues. Do these pistons fit the bores ok?
XRMike
Postby freak power on Sun Mar 21, 2010 11:55 am
XRMike :Freak Power im always inspired by your work and 'thinking outside the box'. This seems like a great way of safley turboing a Zetec without the possible reliability issues. Do these pistons fit the bores ok?
The 1800 zetec bores are 80.6mm
The S3 pistons are 81mm
So not that far off
freak power
Postby XRMike on Sun Mar 21, 2010 11:47 pm
freak power :
So not that far off
Perfect then :D
XRMike
Postby megaflea on Wed Aug 27, 2014 4:56 pm
Hi, this is quite an old post, but i just wanted to confirm,
I am now using 1.8 20v Turbo (AGU) pistons in an 1800 zetec engine (with under piston oil jets)
on a set of prime performance steel H beam rods with the little end rebushed for the 20mm audi floating pin.
the car drove to germany and round the nurberg ring and back again absolutely fine.
They work perfect, compression is a little low around about 8.5:1 with the standard 1.8mm ford composite head gasket, running about 12psi of boost, its making approx 220bhp (rolling road yet to be done), i may at a later date fit the 1mm MLS headgasket from the 1998 mk1 focus.
the pistons are actually 80.95 mm and the bore 81mm
also im running pugeot 106 gti valve springs shimmed +1mm inlet +2mm exhaust
Its a good solid medium budget build which at a later date can take a set of zetec 81mm forged pistons when funds available or if the Audi pistons break (but they are supposedly good for 350bhp)
not necesary but evidence
hope this information helps anyone searching this.
megaflea
Postby freak power on Sat Sep 06, 2014 12:38 pm
I can get these pistons by the boat load
freak power
Postby russ-RST on Sun Sep 07, 2014 10:21 am
That con rod and piston set up is what iv just built in my zt engine so nice to know someone has used with good success. What started off as a budget build just whack in pistons and arp rod bolts now turned abit more into a 300-350 bhp build instead. Freak power what's the going rate for these pistons? I paid about £80 for my set If I remember rightly
russ-RST
Your car: fiesta rs turbo
Postby freak power on Sun Sep 14, 2014 6:54 pm
80 to 100 depending on the condition
freak power
Postby Smo on Tue Sep 16, 2014 1:09 pm
Glad to see more people doing this now! I know I was really interested back when I first saw Freak Power mention this. Seeing this post come back up makes me want to do it again! :lol:
I may have asked this before (probably in this topic!) but do the pistons clear the under piston spray jets OK?
Smo
Postby russ-RST on Tue Sep 16, 2014 5:51 pm
Smo :Glad to see more people doing this now! I know I was really interested back when I first saw Freak Power mention this. Seeing this post come back up makes me want to do it again! :lol:
Your not having your engine back now ! :lol: yea my pistons clear my squirter jets, not by much but they do lol
russ-RST
Postby Smo on Tue Sep 16, 2014 9:22 pm
I still have my good 1.8 ;)
Smo
Postby TomPengelly on Thu Oct 30, 2014 9:07 pm
Hi, im new to this forum...
I have a mk3 fiesta xr2i 16v (1.8 silvertop zetec)
I am planning to carry out a turbo conversion. My prime performance rods were delivered today- to fit 20v turbo pistons. Can anyone tell me what engine code pistons to get? And where to get them? The rods are for a 19mm pin.
And reading this thread so far- i gathered the pistons fit straight in the bore- no rebore needed?
Thanks in advance, Tom
TomPengelly
Your car: Xr2i 16v
Postby freak power on Thu Oct 30, 2014 9:15 pm
TomPengelly :Hi, im new to this forum...
AGU Pistons with dolomite sprint bushes machined into steel rods of your choice.
Boring the block may be needed, just check your piston to wall clearance.
Pistons are good for 400bhp in Audis.
freak power
Postby TomPengelly on Thu Oct 30, 2014 9:36 pm
Cheers, for the reply. I have a set of rods apparently made for these pistons- are the pins 19mm?
If so would it be a straight fit if i got a set of AGU pistons with gudgeon pins?
TomPengelly
Your car: Xr2i 16v
