anyone using 200sx injectors on their ZT??
9 posts • Page 1 of 1
If so what management are you using? and do you know of any other management options?
thanks, Craig.
thanks, Craig.
- E4Fiesta
Re: anyone using 200sx injectors on their ZT??
Hi Mate seems like where in the same boat mate.
I'm looking to use the same injectors but i'm wondering if the FRST managment can take it,using the injector hareness from the nissan.
- macca_179
I have some injctors for sale that go straight into fiesta management, obviously ith a bit of mapping, but you'd need that fo any injector change...
Click info in sig... or ring 07973744159
x x
x x
- Shell
I know megasquirt can run anything, they're the easiest injectors to use as you can retain a zetec fuel rail and use RS1800 inlet manifold. Im sure a good mapper should be able to map FRST management and make it work.
Anyone know for sure, for sure lol?
*bumpsky*
*bumpsky*
- E4Fiesta
E4Fiesta :I know megasquirt can run anything, they're the easiest injectors to use as you can retain a zetec fuel rail and use RS1800 inlet manifold. Im sure a good mapper should be able to map FRST management and make it work.
*bumpsky*
this is exactly what I am trying to do (rs1800 inlet standard rail) but I hear that the 200sx injectors do not fit properly? Whats the deal?
does my big look arse in this?
- The Gilly
I doubt you could get the FRST management to use the 200SX injectors because the injectors probably have a different resistance, try VEMS (http://www.vems.co.uk) bit more expensive than megasquirt but a better system
- SiZT
The injectors do fit properly, you just have to change the bottom little O-ring to the ones from the fiesta injectors. as the fiesta ones are slightly fatter/.
- E4Fiesta
bump, still need infor on management please.
- E4Fiesta
hi there i run megasquirt no problems on my 2.0ltr si try the website in link he is a friend of mine and has fitted megasquirt systems to loads of cars!
i also have a plug and play on my fsi which makes things so much easier !
- frostie
